It will be difficult to open because it has more lock pressure than most blades. It is an attribute of having a folder this heavy and durable. The Lock bar is shorter and it has more tension on the lock than most framelocks. This knife was built to be harder, stronger, and more durable than regular knives. I'm afraid that you will have a harder time opening the knife at its best broke in state, that is the nature of this folder...Take care...Ed
I also feel the O.D of the washer is to small for this knife.
I'm curious about this remark.
Would you care to elaborate?
The washer doesnt have much surface area for the size of the blade and the side load the lock puts on the blade (IMO).....when the pivot is backed off the slightest amount there is no forgiveness.
Are you thinking a larger washer would allow you to loosen the pivot a bit with no side to side play ?
