Fred Sanford
- Sep 3, 2006
Well as some of you know I am very OCD about certain things. Having the tip of a knife sunken well into the handle is one of them. I decided to void my warranty and make mine the way I like it.
The UK Pen Knife came apart much easier than I thought it would and it was easy to put back together. I just had to be patient, work slow, and have good lighting.
I thought you might like to see the pictures.
I would also like to suggest that maybe Sal and crew consider making a small improvement change to the UKPK for the future. I would like to see this hump ground down a tad more from the factory. I understand it's probably laser cut or stamped (I would bet laser cut) but I think if it's laser cut it wouldn't be a huge deal to change that hump where the choil sits when the knife is closed.
Just a suggestion.
On to the pics....in order.
Here is where you can see how much more the tip sits into the handle now. I love it. You can even see that if the blade were about 1/8" longer that it would make the tip covered even more by the handle bump at the butt end.
This shows where I removed material a little bit to sink the tip into the handle.
All back together.
All back together.
