- Sep 29, 2008
Recently picked up a Spyderco UKPK (United Kingdom Pen Knife) in Orange. I believe the original black has been disco'ed, so you can only get these in Orange or Foliage Green. I prefer the orange, but having one in FG would be nice when I don't want to scream "Carrying a knife."
Running off that comment, the knife carries pretty discrete in the pocket. It's clipped by a very low riding wire clip. Clip is tip up, right/left hand swappable. I do rather wish that they had installed slots for tip down carry, as it is my preferred method, but this works, and keeps the knife nestled out of the way.
The name of this knife belies it's intended use. A non locking, sub 3" knife, legal to own and carry in the UK. As a slip joint knife, it's relatively secure. The large forward choil gives your hand a very secure grip on the knife. In testing, I found that even when smacking the black on a table, or intentionally loading the tip, the finder choil prevented the blade from shutting on the fingers. Granted when loading the tip with about 210lbs it gave my finger a strong pinch, it still did not close.
The scales as mentioned are a bright orange G-10. Texture is good, and the simplistic construction keeps everything light. The handle is unlined, but there was still virtually no flex from strong hand pressure.
The spring I believe runs the entire back of the knife. I haven't taken this one apart, so I could be wrong, but it does have a solid metal spacer in the back. The spring is stiff, so you can't flick this knife open at all. No "gravity" knife here.
The blade is a full flat ground, S30V, blade. It has that characteristic leaf shaped design that gives a good amount of belly and excellent tip work.
The handle has the standard Spyderco ergos, excellent ones that is. Comfortable and grippy, the handle had no hot spots during extended cutting.
Overall I love the design. It's an excellent EDC knife that is legal just about everywhere. :thumbup:
