- Apr 5, 2009
I bought this slipit as a no need to think knife. It is very small so it is easy to carry, and seemed like it would be simple to use when I'm preoccupied with other things. The thumb hole allows for one-handed opening and the lack of a lock makes closing simple. I picked the Urban because it is smaller than the UK Pen Knife. The UKPK is almost the same size as a Delica, and I've already got one of those.
http://www.spyderco.com/catalog/details.php?product=382
Ergonomics Excellent
Blade - Wonderful
The flat ground wharncliffe blade sometimes looks wicked, sometimes looks like a fang, and sometimes looks ugly, but never never looks graceful like a leaf blade. However, the straight edge does a great job making predictable cuts with detail work, the small tip gets into little places, it easily opens packages, etc. The wharncliffe shape resembles a karambit tooif one wants to fantasize about combat with such a tiny little knife.
Pocket clip Disappointing
This knife ships for right handed users but the spring makes it hard to swap it for left handed use. I tried briefly but realized it would require a padded vise.
Fit & Finish - Fair
The characteristics of the large spring may be the common cause for all these problems, as the whole knife is built around it. It may be difficult to square it up for a reasonable cost.
Value Fair
With a street price in the $90 range this is no bargain knife. While it is made of G10, has a flat ground VG-10 blade, and the same basic construction as other mid-grade Spyderco products, it doesn't seem to be worth $90 with all the fit and finish issues.
Overall Great concept and feels quite durable, but only so-so execution
- The Urban is small (between a Delica and a key chain knife) but the handle feels very comfortable in my average sized hands.
- The slipit system works as advertised and the knife is easy to open and close.
- Benefit/Warning: The serrated thumb ramp on the back of the blade gives the impression that you could brace against it like with a Delica or Endura, but if you do so it will close the blade. This is nice for easy closing, but I've learned to leave my thumb on top of the scales rather than on the ramp.
Blade - Wonderful
Fit & Finish - Fair
- My blade is slightly off center when closed.
- My pivot pin is slightly off center. I tried to tighten on side with a torx wrench but it did no good.
- Both ends of the spring (behind the blade and at the read end of the grip) are not square. There is a slight angled gap at the back of the blade when the knife is open.
- The underside of the spring is rough and scored across its entire length (inside the handle), and it looks like it was basically sawed off.
Value Fair
