- Oct 22, 2024
So I’ll preface this by saying that I was referred to post this here in hopes that someone at Spyderco would see it and possibly shed some light on this ordeal. I will try and be more accurate in the actual problem as I was downvoted out the ass initially for being unclear in my post. If you want to read that whole debacle, it’s here: https://www.reddit.com/r/spyderco/s/1hS8nTgGLt
Here we go, I purchased a Drunken second hand on knife swap a year, year and a half ago. The original owner (knife god on the swap and I believe has his own shop) cerakoted the clip, backspacer, and hardware. I was told the lock insert and face was protected. With the modification aspect out of the way, I absolutely love the knife. I read how the stock clip isn’t quite the best and agreed with that assessment so I purchased an A. Purvis clip which made the feel of the knife seem on a whole new level. This was about the time I really started purchasing more knives and growing my collection so the Drunken was more or less in a rotation at this point. When the Drunken was actually in rotation, I started to notice that I was having lock failure when I’d use the knife. Disassembled and reassembled quite a few trying to see the issue but to no avail. I was ready to send the knife in for warranty so I put the stock clip back on to send it and it went back to being as it was before I swapped clips. I assumed maybe the Purvis clip was changing the tension on the lockbar so I then purchased a milled Lynch clip for it seeing how it sits completely off of the lockbar. I installed it and had the same exact issue as the Purvis. I went back to the stock clip and it started locking up again but seemed a lot weaker than I remembered and was having more failures than ever before. As it stands now, both of the aftermarket clips makes the knife fail about 90% of the time, the stock clip makes it fail maybe 10% of the time, and with no clip on at all it fails 100% of the time. To expound on me saying lock failure, I can completely open the knife, the lockbar moves into position as it should but it’s like the damn thing is in an oil slick once it touches the blade. If I put any amount of pressure at all on the spine of the blade it will close. I never noticed any sort of rock or play in the blade at all at any point of me having it when it would actually lock up. I sent the knife in and it was received on the 9th of this month, got a letter in the mail on the 21st reading as follows:
Greetings from Golden, Colorado!
We are happy to see that your knife has been put to good use. We regret to inform you that your C235 CFTIP DRUNKEN has an issue that unfortunately is not a warranty issue and cannot be repaired. Because you are a valued Spyderco customer, we would like to extend a special offer to you.
You will have a choice of one of the following options:
Please keep in mind we are unable to give you a monetary refund for your knife.
You can either contact us at 303-279-8383, ext 3, or ext 230, or you can complete the form below and fax or mail it back to us. In addition you MUST contact Spyderco Warranty directly, this is not valid through the Factory Outlet Store or your local dealer.
If we do not hear from you by 11/15/24, we will return your original knife to you with no further option for replacement Thank you for your continued support of Spyderco Knives and Accessories and we look forward to hearing from you soon.
Best Regards,
Spyderco Warranty and Repair
I’m at a loss for words on this matter. I understand that the knife was technically modified, but it seems like it’s a mechanical issue with the lock and not something that was aided by me swapping clips or the original owner cerakoting parts. I almost feel like me taking the 45% off of MSRP on a new Drunken will put me in a deficit seeing how they’d keep my knife. For them to recommend I retire the knife if I choose to have it returned also seems off. At this point, I feel like I’m in a corner. I don’t have my knife, potentially have to fork over another wad of cash if I want it replaced, or deal with a knife that they state will cause loss or injury. I still don’t even know what the damn issue is. Again, I’m a newbie when it comes to the grand scheme of the knife world, but I was really hoping for the Drunken to be the first of many Spydercos I’d own and this situation has soured that idea. I apologize for the lengthy post, I’m just trying to be as concise as possible.
- As a current owner of a Spyderco product, you can take a one-time discount of 45% off of MSRP on any one Spyderco product based on the product availablity seen on our online catalog at Spyderco.com (sorry, exclusives and coming soon items are not available for purchase with the discount). If you choose this option, your knife will be destroyed or forwarded to our Research and Development department for study.
- We can return your original item to you in the same condition we received it.
Best Regards,
