Spyderco's riveting manner of assembling knives.(HaHa)
Are all Spyderco knives riveted together, or are some knives assembled with screws? Which knives, if any, are put together with screws? Why are Spyderco knives riveted together? I like the option of taking my knives apart for cleaning, smoothing the action, etc.
The models in the lower price range are riveted together. It saves cost plus Sal has stated that there isn't a lot of ELU demand to take apart the cheaper Spydies.
Any of the more expensive (non stainless-handle) models can be taken apart. It would take too long to name them all.
Thanks for setting me straight. I own a Catcherman and the local knifestore carries several Spyderco models, all of which are riveted. I also read something in a knife magazine about adjusting a Spyderco's pivot pin tightness by tapping on the pivot rivet with a hammer.
Now that I know, I can start looking for my next Spyderco knife!
Thanks,
Chuck
No problem. If we can help you with your search for your next Spydie, don't hesitate to ask!
And yes, people around here use the hammer on the pins trick. Just make sure and do it lightly!
Originally posted by Chuck Asher
...I also read something in a knife magazine about adjusting a Spyderco's pivot pin tightness by tapping on the pivot rivet with a hammer.
Thanks,
Chuck
That method works very well, but as TOTC said, make SURE to tap lightly, as it's easy to get them TOO tight...Keep checking the tightening progress. Use a flat-bottomed punch that has had the contact area polished so that you won't leave "tool marks" on the surface of the pin. It also helps to have the knife laying on a solid table, with a clean, flat piece of steel under the knife.
I'm one of those idiots who tapped mine too hard and ended up with a Snap-It that I could barely open with one hand! I would strongly advise against it, from personal experience, unless the blade is VERY loose. Then, I would send it to Spyderco. No more "home fix-ups" for me. Just my two cents.
Leo G.
Originally posted by jefroman
Which side of the rivet do you tapp? The right or left side?
Jeff
Jeff,
I don't think it really matters which side, as long as the side that's not being "tapped" is supported by someting hard, like a flat piece of steel.
