Spyderfly sharpening question??
O.k I have rainbow Spyderfly that is pretty dull. Here's the problem, the angles on this thing are so weird that is hard to do anything with it. The leaf recurve is so narrow that it makes it impossible to sneak a stone in there, and the sharpmaker rods are not coarse enough to do anything really. Could this be the rainbow coating that is making this so difficult? I seem to be an idiot as I can"t figure out how to put sandpaper on the sharpmaker rods.(I just slce them off in two passes or the sandpaper is stripped in two passes) Am I just doomed to pay the $70 for diamond rods? Or does someone know a technique to solve this.
Thanks!-Mike
Buy the diamond rods. You'll get a lot of use out of them beyond your Spyderfly. I need to buy a set myself.
How wide are lansky stones? For the Spyderflly it looks like a stone would have to be 1/2 inch or narrower to fit in the recurve. I looked up Lansky on the search but only got angles not width. Anyone have one and know? (I can pick one of these up for about $25 thats why I'm curious!)
I own a Spyderfly and had the same problem. This is the solution to it: Smith's Retractable Diamond Knife and Tool Sharpener
Shouldn't even set you back $10.
-KC
Rainbow coating?
Knifeclerk said:
Rainbow coating?
Spyderco did a run of Spyderflys with a matte rainbow coating (more like SOG rather than Kershaw).
I doubt the rainbow coating is what's making it hard to sharpen your knife. The coating is tough, but it's not so tough that it'd resist an alumina-ceramic sharpening stone for more than a couple passes.
The problem is the Sharpmaker. As good a tool as it is, it's one weakness is reprofiling. Even using the medium rods, it's like trying to drain a swimming pool with a spoon. Combine this with the fact that the Spyderfly is rather oddly ground (necessary with the shape of its blade), and you're in for a loooong spell putting a new edge on it.
The diamond rods will make things much quicker. Or, for about $20 you can get one of those oval shaped sharpeners (that look like steels, but are diamond coated). I have a medium grit one that I used for recurves before I got the Sharpmaker w/diamond rods.
Actually, considering the grind of the Spyderfly, it might work better to freehand rather than using the Sharpmaker. At least on my examples, the edge on the Spyderfly isn't the same bevel angle at all parts of the blade. At its broadest, I'd say its a normal angle, or maybe a bit less acute, but at its narrowest, near the base, it's much more obtuse. It'd take a long time to reprofile one of my Spyderflys with the same angle all-around with my Sharpmaker, even with the diamod rods. Getting a sharp edge by freehanding with my diamond steel however would take only a few seconds.
samhain73 said:
The leaf recurve is so narrow that it makes it impossible to sneak a stone in there ...
Use the corners of the hones.
..... slice them off in two passes or the sandpaper is stripped in two passes
Not all sandpaper is equal, it works better on the flats than the edges however.
-Cliff
