Cliff Stamp
BANNED
- Oct 5, 1998
The knife weighs a mere 35 g, can even be carried clipped in a shirt pocket (tip down). The stock is 0.015", blade is 3 cm wide, 6.6 cm blade (6.2 cm sharpened), which small choil notch.
NIB the serrations are very sharp. Each was tested on light thread and scored a blazing 85 +/- 10 g. This is the sharpest knife NIB I have seen. The teeth are ground very acute, 0.037" thick behind the grind which is ~16-17 degrees *included*.
The handle is very comfortable in a grip high up on the fingers with the thumb resting on the back of the blade. This hold works well in precision cutting which would be the main strength of this blade. The ergonomics are however rather poor in a hammer grip due to the sharp inside edges of the Zytel (sandpaper would fix that) and the bottom portion of the clip is also a high pressure point. It is decently comfortable in reverse grips, more ergonomics with the facing clip out to prevent abrasion. Texture seems secure without being overly abrasive.
The blade opens smoothly and easily through the Spyderco hole. There is no play sideways or vertical, lock is clean and tight. It easily handles various fast spine whacks with no effects, neither release or any induction of play. The indendation in the lock bar release also makes it impossible to white knuckle fail it either in any normal grip. A very secure lock eith easily enough strength to handle the light use this folder is designed for.
No cutting done as this is a gift for someone else. Same person was very pleased with the performance of a serrated Endura (wore it out), so I have no doubt that this one will be put to use.
-Cliff
-Cliff
