einsteinjon
Platinum Member
- Dec 22, 2008
Hi all,
Just got my 0561 today and I noticed that it has a squeaky tone when opening/closing it slowly (i.e. grabbing the blade between my fingers and opening slowly rather than using the flipper or studs). It is like the tone when you have a slightly moistened pad of your finger and you rub it around the rim of a wine glass. Is this normal? Should I oil it? I have opened/closed the knife with the flipper about 100 times now and it's still there...
Also, I noticed that when closed, the lockbar can be pushed in ever so slightly and it then stays in that position. After doing this, the knife is a lot more difficult to open with the flipper or studs. It seems like the detent ball is either being pushed slightly into the lockbar, or pushed slightly into the blade, hence the stiffer opening. Is this normal? Will it work itself out with break-in?
Thanks all for your input! Just looking to learn about this knife as I've read they can be tough to open at first.
