Isn't 52100 also the speculated "Corbon V" that Cold Steel used at one time?
Here is his exact reply to me on a similar question from a past thread. This is the whole reply without editing or corrections. I should have used it in the first place but tried to shorten it by paraphrasing a bit.
"I noticed that you and a number of folks have been guessing what this is.
I have posted this before but it appears that a lot of folks have not seeen it.
CV--Chorme Vanadium Steel and Carbon V are all the very same steel.
This is not a mistery steel. It is not a new steel. It had been made by the hundreds of tons For many many ywears and used by ALL the major Knife Companies for Decades.
It is 0170-6 cutlery Steel...It was developed in the 1950's by sharon Steel specifically for Knives.
It is an enhanced 1095. They added Nickel--Chromium and a trace of Vanadium. it was a patented steel of Sharon.
Everybody used it. it was called by cute names by some companies --Chrome-Vanadium by others.
This was the original Steel chosen by both Lynn Thomson for his Trailmaster and me for the Old Mamba. We all used it until 1988.
sharon Steel went Bankrupt in 1988. None of us could get it and no other mill would duplicate it because the papent was still in effect.
We all switched to other steels.
A couple of years ago Case and Camillus Found a mill that would duplicate the Chemistry and they ordered a heat lot--+/_ 100,000 lbs.
Case had thier portion of the heat lot rolled to pocket knife sizes and Camillius had thier portion rolled to use for Lynn on his U.S. made knives and the Becker line.
This was an excellent steel and will out perform 1095. I have used it in a lot of the early Blackjacks. I still have some and made our goloks and Northwind Swords from it.
I have no idea why this question keeps comming up. All of this is common knowledge in the industry.
I suspect that nobody will be using it except for Case, Cammilius, Becker, Westerm and Cold Steel.
As I'm sure you know that Case makes thier knives and Camillius makes all of the other brands that I just mentioned.
I doubt that you will have any better luck relaying this info either. It dosen't seem that folks want the truth.
It's more fun for folks to speculate....................."
