Stabilize for wood and resin scales?
I am planning on making some kitchen knives (from kits) and making scales with locust wood cast with colored epoxy.
Do I need to stabilize the wood before casting?
Can I cast as a block and then cut into scales afterwards or should I cast each scale closer to size?
If this is the locust wood as in "Black Locust" I don't think you need to work about stabilizing. That stuff is HARD 'n DENSE! Fence posts last 100 yrs and more.
Yeah I don’t think locust needs stabilizing. I would do it all as a block and then split your block though. Just one pour vs 2
There was a thread a while ago discussing what wood needs stabilizing, what doesn't:
Someone commented that Black Locust doesn't need stabilising.
I would contact the maker of the casting resin you intend to use. I seem to recall Curtis at Turn Tex (Cactus Juice) saying his Alumilite resin bonds better to stabilized woods. That would be the a good reason to stabilize even black locust.
i would also worry about bubbles from the wood into the resin. so you may want to seal the end at least
