OK. Does it also require longer vacuumizing process or only longer penetrating process after the releasing of the vacuum?Low end and high end are not the best terms for the question.
Softer woods allow the resin to penetrate faster. Examples are maple walnut, and sycamore.
Harder woods are denser, and the resin takes longer to penetrate. Examples are ebony, blackwood, desert ironwood.
Another person from a facebook group told that Amboyna burl needs at least a week under 120 psi pressure to get soaked through or a month without pressure.The softer, more open pore type woods are what's used for home stabilizing. Great success with those type woods. Dense small pore woods like Stacy mentioned, Rosewoods, etc are not at all suitable for home stabilizing. They don't really benefit stabilizing. Per the owner of Cactus Juice even Black Walnut isn't a good wood for home stabilizing as it just doesn't soak up much resin. K&G does a great job with Black Walnut.
For the denser woods (not Rosewood, ebony, etc), yes, you'll have to pull a vacuum longer, then soak MUCH longer, perhaps a day or so to get as much resin as possible.
Question that I asked elsewhere with no response. Like 10 yrs ago, several owners of CRK Mnandi's (which I collect) complained to CRK that their knives with ivory or light mammoth scales (stabilized), when the knives were carried in the 5th pocket of jeans, leeched some of the blue dye. I saw the photos.I have no experience with Amboyna burl - does it sink in fresh water? Or, float just barely above water? As expensive as a good piece of Amboyna burl is I'd have K&G so do the stabilizing. Not some home stabilizing system. I do some Cactus Juice stabilizing with good results, 100% penetration and finished product normally sinking in water, or barely floating.
Stabilizing does not make the wood or ivory completely impermeable, it makes it so it won't absorb the water into the wood and make it swell. You can soak a block of stabilized wood in water and set it on end on a paper towel and the water will slowly run out the pores.
I don't know about the CRK situation, but the dye from jeans should be stable and the ivory should not have had any active chemicals that would dissolve the dye. I suspect some sort of solvent-based stabilization experiment or improperly done stabilizing on that material.
