Stacked Leather handle..
Im planning a leather handle on my newest project..heres my question ..i got them wet,clamped them up let them dry..now do i just epoxy them together and treat them like a solid handle piece? Any suggestions would be appreciated..thanks Luke
Basicly the way I do it is to cut the leather into 1 1/4" squares and soak 7 or so at a time with accure glass epoxy and stack and press. I use an acid brush to soak the squares, and have a press jig I use to compress the blocks, it's nothing more than a couple of 4x4x1/2" plates and a couple pieces of 1/2" angle iron welded to the bottom piece. Put a layer of wax paper down, stack the epoxyed leather, anouther layer of wax paper and stick it in the 20 ton shop press and mash the crap out of it. I leave the block in at least over night to cure. take it out, square it up on the band saw and treat like a block of wood.
I've tried soaking with water and compressing, then soaking with supper glue and so forth, the best results I've gotten so far have been using accure glass and just smashing together. Make sure you work the epoxy in good, that's one reason I like the slow cure time of accureglass.
The reason I do it this way is because I haven't made a full leather handle yet, just leather and stag. A full leather handle can be compressed with the but cap, but I'd probably still do it this way. Makes the leather very tough and stabile. After sanding and polishing and light coat of wax your pretty much done.
I was going to die the leather usmc black..will the dye take after the epoxy is dry?thanks fr the response
no - dye first then glue.........cut the leather in pieces and pre-shape a little oversized. Then dump in a closed container of dye and let them soak in the dye until it goes all the way through - or buy a pre-dyed black shoulder from Weaver Leather or Demers Leather.......
Wild Rose thanks ..i was hoping you might chime in here too..my wife and i are big time admirers of your work..ill do the dying first..glad i checked in! thanks alot guys. Luke
