Im posting this after a few requests on how I did it. Im not one of the most talented people who have re-handled a khukuri and Ive seen some beautiful work done to them. As to why and how I re-handled my Bilton in stacked leather. First up is why; I wanted a khukuri that was comfortable to carry during my walks in the desert. Theres not much to chop out here so a full size khukuri would be wasted. I wanted a knife that was comfortable to carry, strong and reliable enough for cutting chores, and easy to conceal so I didnt scare the sheeple. I also wanted something that was unique, I know I could carry a pukko or a K-Bar but how many people carry a khukuri? Present company excluded. The problem with the Bilton is that the handle was just too small for me to control. I didnt really like the three finger grip that the current handle allowed, so I decided to re-handle it. The first thing I had to do was get the old one off. I taped the blade then I re-taped it and just to make sure that it didnt cut me I taped it again. See a trend here use a lot of tape or you could get cut. Then I clamped the blade in a vise. I then began to heat the handle at the bolster junction with a heat gun. I would pull on the handle wearing a heavy glove (careful its hot) until it came off. Once I had the handle off I was time to clean the laha, this stuff is like concrete. I used my belt sander to clean it of the tang and a Dremel to clean out the bolster. Be careful not to overheat the blade I keep dunking it in a bucket of water when I was too hot to handle. Then I needed to extend the tang. I used a bolt that I split with my Dremel. Since Im not a welder I had a buddy weld the bolt to the tang; which I cleaned up with the belt sander again. I then cut a whole bunch of leather squares, punched a hole in the middle and stuck them on a bolt with a fender washer on each end. I then soaked the leather in water and compressed them by tightening the bolt until I would go ant further. With I waited for them to dry (24 hours) I used marine epoxy putty to fill the cavity in the bolster. This stuff is like Pla-Dough until it cures, then its as hard as the laha that its replacing. After everything is cured and dry its time for assembly you may need to enlarge a few of the leather squares to fit over the tang area. I then used two ton epoxy between each square and to fill any gaps between the leather and the tang. I continue to stack and epoxy until I had the desired length for the handle I put a piece of brass over the end for a pommel and peened over the end of the tang. I had ground the threads off the bolt I used to extend the tang. The hole I drilled in the brass was tight so that I could beat it down and compress the leather while the epoxy cured. Once everything had cured again, I sanded the handle into the desired shaped with the belt sander. I would go real slowly to avoid taking off too much. Then I switched to a worn 120 grit belt for final sanding where I would dip the handle in water and sand. I would repeat this until the handle was nice and smooth. Once I had it nice and smooth I used my wifes paraffin wax bath to soak the handle in, watching the color change until I had it to the darkness I wanted it. Then I polished it with an old t-shirt, kind of like shinning shoes. Im sorry for the lack of pictures during the process but I didnt have a camera during this time. The pictures below show the end result. Id be happy for any comments from you guys especially from the more knowledgeable. This way I can better myself. Most of the things I did I researched through the forums, youd be amazed at the wealth of information you can find in the place.
Bilton with scabbard
Close up of the handle (side view)
Close up (top view)
Close up of the pommel (went a little crazy with the hammer)
In hand picture
New and old comparison
Close up (top view)
In hand picture
