- Oct 12, 2019
Thanks!! Apparently not common either.That's a gorgeous hatchet!
Its highly polished so I don't want to use anything abrasive. Guess I'll leave it be.Next step for me would be to use some “Bar Keepers Friend” and a damp clean sponge. If that’s not enough then buffing lightly with some oily 000 steel wool, however even that might mar the original finish depending upon how polished it is.
Actual refinishing would involve many grits of sand paper and a buffing wheel.
If you plan to use it then I would just keep it clean and not worry about the staining. On the other hand, if you want to preserve the value to sell one day, you should either just leave it alone and keep it oiled, or consider a complete refinish. Just “fixing” this finish will likely devalue the hatchet.
Its been used the edge isn't perfect and its either very old staining or someone used something to clean it that stained it not sure but its still holds it mirror finish with no pitting or real scratches.I'd wondered if the hatchet had been used(?) at some time, and if the staining might be some old remains of pitch/sap embedded in pits in the steel. If it were sap, I know something like Goo Gone, WD-40 or mineral spirits can clean up tree sap without altering the finish. I use Goo Gone, applied and left to soak for maybe ~20 minutes - then wipe off the sap. Or, the 'staining' might just be etched pitting of the steel itself, for which only some abrasive method can remove that.
As others have said though, probably better to leave it be. That looks like a nice find, just as it is.![]()
