KnuckleDownKnives
Time to make the doughnuts..
- Feb 12, 2015
What type of stainless is good for making bolsters? Is 316/316L suitable? I see usknifemaker carries 416 is that preferable?
I use 416 bought in round stock and forged to dimension
416 I think you want to harden because it doesn't reach it's full corrosion resistance annealed but I could very well be wrong.
416 is harder to find outside of the knife suppliers in flat stock.
I don't know that it needs to be. I've used it on bolsters in the annealed state as well. I'm trying to recall a discussion here where I believe it was said that it should be hardened to reach it's full corrosion resistance but like I said, I might be wrong. I don't know if that makes sense chemically or not. I'm thinking that if it comes fully spheroid annealed, then some of it's chromium is just balled up in their own little spheroids and not in full distribution, and hardening it helps distribute the chromium appropriately?
Corrosion Resistance
Grade 416 steels are highly resistant to acids, alkalis, fresh water and dry air. However, they are less corrosion resistant than non-free-machining steels, austenitic grades and grade 430 Ferritic alloys with 17% chromium. These steels are hardened to obtain maximum corrosion resistance and smooth surface. 416 free-machining grades with high sulphur content are inappropriate for chloride and marine environments.
Corrosion Resistance:
Demonstrates corrosion resistance to natural food acids, waste products, basic and neutral salts, natural waters, and most atmospheric conditions
Less resistant that the austenitic grades of stainless steel and also the 17% chromium ferritic alloys
High sulfur, free-machining grades like Alloy 416 are unsuitable for marine or other chloride exposure
Maximum corrosion resistance is achieved in the hardened condition, with a smooth surface finish
What makes 416 machinable is the added sulfur - not that it's spheroidal. Without the sulfur, it's basically 410.
Same thing with the 303. It has added sulfur to give it machinability. That's the difference between it and 304. (304 is worthless for us).
Yes I understand about the sulfur, I was just speculating on why hardening would effect corrosion resistence. I use 304 and 316 quite often because it's practically free to me since we scrap so much at work. I wouldn't way it's useless. It makes excellent damascus and san mai.
416 is what you want. The downside in recent years has been that it is impossible to find really thin 416 stock, so you have to use 410 whihcis an adventure when trying to cut it on the bandsaw. 416 is a dream to drill, mill and finish.
