- May 3, 2002
Lots to talk about. I figured I'd put in in one post instead of 2.
I just got a Stainless-handle Endura the other day. I really like the weight of the metal handle, but it's a bit slick. It's not a problem when I'm working with the knife, but it IS a problem on the draw. It's really tough to get a quick grab and pull. I've slipped and had to re-try more often than not. I wonder if it might get a little better with some wear.
Perhaps Spyderco shouldn't polish them quite so finely. But then, it's darn good-looking that way. Mine is nearly mirror-polished with a very slight verticle brush finish. (Great for engraving; I'm sure.)
Ya know what would be sweet? It would be sweet if SC checkered the top inch of the knife on both sides like the front strap of some 1911s! THAT would be cool.
Maybe I'll send mine to the Spyderco Custom Shop to have that done.
He-he.
Not to complain but does SC not heat-treat their steel themselves? My beloved Meercat edge (AUS-6) was dull with rollover and chips in 4 days! That was a super disappointment. I DID fall in love with the knife and use the hell out of it in those 4 days but I only cut corrigated cardboard and plastic blister packs open with it. I totally resharpened it with my a Lansky/Strop method inside of 20 minutes at the same angle as the factory but with a more polished edge. I hope this one lasts longer because I'm sure I took more care and put a cleaner edge on it than the factory probably did.
But then, my ATS-55 Lum Tanto that I USE (I put away the other for when I wear out the first.) gets dull rather easily too. Only difference is that I've never had to sharpen the Lum Tanto. I have always been able to bring the edge back to shaving with a loaded strop.
Hopefully their VG-10 will do better.
From my understanding of knife companies, some companies buy knife steel and DON'T heat treat it and just use it as it is. (CRKT for example) Other companies (SOG for example) painstakingly heat-treat their steels. (I've had great luck with the steel on even the cheapest SOG knives.)
So what does SC do? Is this the reason their knives seem to be a lot for the money? Do they cut a corner here?
