- Dec 24, 2014
So I'm needing a little info on this when the time comes. I bought a 3x24 sheet of .062" 410 stainless from knife kits for the liner lock blades I'm going to make. The thing that is confusing me is the spring tempering. Here is knifekits heat treat instructions:
Heat Treat Instructions:
For creating spring temper: We recommend an atmosphere furnace, or foil wrapping the steel to stop decarbonization. Austenize at 1800-1850° degrees F. for 5-10 minutes, or until the material is heated completely. Then air cool with a fan, or quench press, until the temperature is under 110° degrees. Temper twice at 750° degrees for two hours, allowing cooling between cycles to less than 110° degrees F.
NOTE: Heat treat results may vary with the oven and operator. We recommend 38-45 RC for best results.
If the liner already has the lock bent, how can you plate quench it after hardening? Or do they mean something different by quench press? Could I just blow it with compressed air? Any tips on this would be great.
