I started this search with the intention to find a workable material that I would be able to shape into a functional kukri scabbard with a minimum of effort and a minimum of technical skills.
I wanted something that had the following characteristics:
1- Very lightweight
2- Extremely durable
3- Resistant to the blade cutting through it
4- Easy to form and mold
5- Cheap
6- Waterproof
7- Unbreakable
8- Thin
9- Easy to carry in a pack,on a belt or shoulder sling
10-Dual use and easy constructed as a scabbard for machetes,knives,kukris or goloks
I believe I found the near perfect material at the nearby Lowes Store.
It is named:
Plastex waterproof wall panel
.060 x 4' x 8'
Bright White
Made by Parkland Plastics
Website:http://www.parklandplastics.com/
Cost for a sheet was $14.24
Stock # 72405
The other materials I needed to start my custom scabbard making project were:
1-A hand riveting tool for blind pop rivets
2-Aluminum rivets--- $5.99 for 100 pcs
1/8" diameter
Grip range-1/16" - 1/8"
3-Backup plates aluminum for use with all brands of rivet tools 1/8" diameter--$1.49 for
30 pieces
4-A pair of tin shears, Prosnip wirecutters Model 20SL, or a pair of heavy duty scissors to
cut the material to scabbard shape.
5- A Dremel tool with a 1/8" bit for drilling the rivet holes
I just finished making my first four scabbards this afternoon so this is another learn by trial and error adventure but so far I am EXTREMELY pleased with the results. Mind you these are by no means beautiful products but they sure are light and practical.
Here's how I'm proceeding: I initially lay the kukri or machete on the material and outline it with a magic marker.
Then I add a minimun of one inch extra material around the perimeter of the outline to put the rivets in in order to rivet the two scabbard sides together.
Then I use the dremel tool with a tiny 1/8 " drill to drill the rivet holes. Then simply put in the rivets.
I have not decided how I want to do the belt loop or carrying loop yet and would be grateful for any ideas.
I have never worked with this material before and I would like to know if this material binds well with glue or epoxy. I selected aluminum rivets because they resist rust and the blde,when sheathed,won't cut through.
There's one thing for sure; with a 4'by 8' sheet of this stuff you can experiment til the cows come home and still have a bunch left over.
1- Very lightweight
5- Cheap
6- Waterproof
7- Unbreakable
8- Thin
It is named:
.060 x 4' x 8'
Bright White
Stock # 72405
1/8" diameter
30 pieces
