Starmate serrations?
That the serrations on a Starmate are different because the steel has different properties I've read, and mostly understood why, so that's not my question.
<A HREF="http://www.canit.se/%7Egriffon/diverse/knives/tmpimg/tmp_starmate.jpg"><IMG STYLE="float: right" SRC="http://www.canit.se/%7Egriffon/diverse/knives/tmpimg/_tmp_starmate.jpg"></A> My question is: Are they also designed to perform differently than (for example) on the C15? On that, and some other knives, it feels sort of obvious what tasks they do better than the plain edge, but on the Starmate, I've so far not found an application where they are clearly superior to the unusually good plain edge, and that includes cutting:
cardboard,
plastic wrapping,
the hard plastic bands holding boxes together,
grass (with the plain edge you can push straight through a bunch of straws),
fresh and dry wooden branches.
(As you can see from the picture, this doesn't stop me from using the serrations anyway, so they aren't "bad" in any way.)
For at least some of these materials, serrations work better than the plain part of the edge on some other knives. But in these cases, the serrated part usually is sharper also for "push" cutting than the plain part.
Is perhaps the advantage not "ease of cutting", but rather "edge retention" with some of these materials?
[This message has been edited by Griffon (edited 16 June 1999).]
Griffon - A very sharp plain edge should perform right along side a very sharp serrated edge on most materials. Some kinds of rope and kevlar might be exceptions. Edge retention, however, as you mentioned is generally 2 to for times as great on work knives and 10 to 20 times as great on kitchen knives cutting on a cutting board.
sal
Living by the sea I get a free supply of rope that floats onto the shore from the fishing fleet and IMHO serrations cut much better than a plain edge. Tonight I used my Starmate on 1" and 2" manilla and nylon rope. I used the serrations, the plain edge and the full blade (plain and serrated).
The serrations were able to cut through the rope much faster (4 swipes vs the 7 or 8). I even tied some rope against a log and did some swiping at the line. The knife did great and the serrations just ate the rope up like it was starving. Cutting against a log the serrations were better, too. Just my opinion, but you can't beat the serrations when you're dealing with rope.
I guess that's why I like Spyderco serrations so much.
~Greg~
