Starmate suggestion
Double Edge Dave
Moderator and Gold Member
I love the starmate.It`s design and function are great.It would be helpful to have scoring on the back side of the hump,similar to the military.this would be helpful when choking up to do fine cutting.
My 2/100 of a dollar.
David
AKTI#150
I'll second, third, and fourth that suggestion. This is sorely needed on this knife.
Kelly
SenatorsPlace.com
AKTI Member #A000289
Deo Vindice
Sal, Bob T, Vince,
The Starmate is a great knife and you have done a great job. I really like the light weight, solid lock up and blade shape. If you are on the topic of product improvement, I would like to add my suggestions. Corduroy suggested cutting out index notch where the lock is on the other scale. I'll second that. A slight thumb scallop to help find the opening hole would be nice and bead blasting the clip to a non-shiny grey would make me really happy. Small things that don't stop me from enjoying a really nice knife.
Damon
Nah, don't go changin' (the handle) to try to please me... Oh wait. What I mean is, if you want to make the fron guard a little more pronounced, that's one thing, but don't scoop too much out of the cutout where the liner is -- I like it just the way it is.
On the other hand, a glossy black clip (ala Calypso) and a Rolling Lock would make it perfect
-- Carl
I am not quoting Billy Joel, I am NOT quoting Billy Joel! NOT NOT NOT!
So do I. The only change I'd consider to the handle would be a slight recess on the "left hand opening side" of the hole, like on my C19G. Nor would I like it as much if it had grooves on the back of the hump. That it doesn't and only has them slightly recessed between the scales is one of the good points of this knife.
Urban Fredriksson
www.canit.se/%7Egriffon/
See above for:
* The F1's aircrew sheath photo
I'll second Urban's oppinion.
I'd like to see an improvement in easier opening the knife with the left hand. And when wwe are talking about improvements a chmbfered hole would be great.
Greetings
red
I love it the way it is.
All these suggestions can be completed by the individual after purchase if they so desire. There is nothing about the current design that does not facilitate these changes to be done by the ELU or a professional knife customizer. Hence, the design is perfect.
(My .02)
I did show my Starmate mods to Sal and the gang while in Golden, and they didn't seem too thrilled. I don't blame them - finger grooves have a couple of problems associated with them.
The first is that (I find) any reasonable size groove will fit about 1/3 of the users well and 1/3 not so well, and leave the remaining 1/3 with an uncomfortable, ill-fitting grip. That's just because of the way hands vary. The lock cutout on the Starmate is really too small to make a good finger groove, so I had to extend it formard slightly in addition to making a counterpart in the back scale. The result fits me well, but wouldn't work for someone with very large hands - and there is no room to widen it further.
The second issue is that grip security and mobility are often a trade-off. I've been carrying an AFCK for years and have grown to like a finger-groove that "locks in" the grip. On the stock Starmate, there are really only slight humps to index the handle by and dictate how you grip it, so it supports a very loose and mobile grip. My modification changes this enormously, the finger-groove dictating a specific saber-grip at the the expense of some versatility.
Do I like my Starmate better with its modifications? Absolutely. Would they work for you? Probably, unless you have very large hands. Should they be a "standard" feature? Probably not. This would leave some users "out in the cold" with a grip they couldn't use, plus it's Bob Terzuola's design, not mine. And, like most things, there are trade-offs to the knife's appearance and function:
Good - more secure grip; better access to the hole for "drop" opening.
Bad - less versatile, mobile grip; one more curve on an already awkward-looking handle.
In short, the Spyderco folks have seen what I've done, they've considered it, and I wouldn't expect to see it become standard.
I do think they should consider more grooving on the spine, though. My thumb falls mostly on the grooving already there, but it has little effect sandwiched between the scales. Many folks I've seen with larger thumbs reach farther up the spine, where there is no grooving at all. Like the shallow false edge, the grooving seems surprisingly cosmetic on a knife from such a function-oriented designer.
-Drew
I liked the Starmate so well that I bought both variations. The Part Serrated one has the lowest number so I've been saving it back and useing the plain edged version. It stays super sharp although I don't risk buggering it up with packing tape and other task that can be handled with a cheapo razor knife.
lbwheat
