Hope this helps, from Anne from CRK.
-When we assemble Umnumzaans we do use Loctite. It is 222MS, low strength that creates enough bond to prevent the pivot from coming undone but one that can be broken quite easily when you wish to disassemble the knife. Do not use medium or high strength Loctite – it will cause trouble later!
Only a tiny droplet of Loctite is needed on the threads of the male screw – this is important as it adds to the strength of the pivot assembly. If no Loctite is used, the pivot will loosen continually.
The Umnumzaan take down kit contains two delrin tools, two allen wrenches, a small container of Loctite and instructions on how to dis- and re-assemble. The directions detail where to place the Loctite and the lubricant.
Purchase of the kit is a small investment that will keep your knife in great condition!
Anne
