I probably should have put this in my OP, I've been in contact with Stewart Townsend, so I'd have to ask about who he uses to heat treat and if he can only use select steels.
Antionio - I intend to use it as a 'primary' knife, like what you see people use their izula for - when I'm in places where a small knife is more acceptable (not that this concerns me much) but more so when on day hikes or short trips, and all I want to carry is a small, but capable knife, and thats why I went with the 4mm thickness
Field sharpening - thats a good point, hadn't thought about that, however I did get a couple of field hones from KSF, heres a quick pic with a bravo necker for a size comparison.
I think that if I am able to maintain it with a few sheets of various sandpaper grits and the little strop, I should be good to go.
About corrosion resistance, I'm pretty easy - The A2 steel on my bravo 1 has been quite good, no rust, a slight patina from use, and I only wipe it down with a tuff cloth every month or so if I remember to do so in the first place. But then thats the only carbon steel I have, so I'm not sure how it compares to other carbon steels.
Hardness level, I'm not too sure what would be the best hardness level for a small necker, that would get some hard use.
HOC - Hey mate, well I figure the BRKT Lil Canadian in CPM 3V has similar specs to what I want, and its about 187 AUD, and this is the cheapest model, with just g10 handles, but since this won't be made with handles (will put some on later) I figure that the cost shouldn't be too bad.
If I were to get 2 made, I'd probably have to sell one of my organs
And yeah, as you probably know, Stewart Townsend is an Aussie knife maker. There are some photos of his work on Laventrix.
knifeknut - Thanks for those other steel suggestions I'll definately do some research on those.
