- Jul 21, 2011
Does anyone know if the ZT Hinderer collaborations are compatible with the Steel Flame accessories? And is the 45acp Lockbar Stabilizer compatible with the ZT 0300 line?
I stuck a .45 in my 0300 a few months back, here is how it looked (Thread is a good read) http://www.bladeforums.com/forums/s...id-I-wait-to-buy-a-ZT-!!!!?highlight=turk.919 Pics are on both pages.
Good to go, thanks for the info. So to make a lockbar stabilizer from a bullet, you just take an expended cartdridge, cut the rim off, and drill a hole where the primer was for the screw? That seems frighteningly simple.
i might have to try to do this when i get a 550
Ok can someone make a tutorial?
^ That is about how I did it, .45's and .44's are perfect for ZT 30X's. I used a cutoff wheel on my dremel and a spent casing from shooting earlier in the day. After that I took a small drill bit and drilled through the center of the primer (Easy to do since that is where the firing pin strikes) Then I sanded the primer down to make the screw head recessed. Took about 20 minutes.
