OK, so I bought a sheet of 1/64" stainless to make a kitchen frosting spatula. It's somewhat ductile, and cuts fairly easily with aviation snips. The bad news is, it curls like a @#<;$&*?! I'm cooling completely in cold water after every pass, grinding with very light pressure, working in a circular pattern, it doesn't matter. Yes, I can lay the blank on a belt sander when I'm done. I'm doing all the work with the same side up for that reason. But am I missing any trick or technique that will minimize the curling further? I literally can not work it any lighter or faster. The pattern is like a large tapered cotton ear swab, so shearing right to size would be pretty difficult. I plan to serrate a couple inches of one edge. It's hard to pry the one I used as a model from the cook's grip, but I'd bet any amount that one was stamped. I question if this sheet was tempered, it has minimal memory. So I'm planning to temper it.
