- Jun 4, 2023
If I have a steel where Mf is below room temperature, would the RA disappear over time at room temperature and how long could it take or is Ra fixed?
Do I understand you're saying Quench, freezer, temper, freezer, temper, freezer, temper? 3 times in freezer and 3 tempers?If none of that is available, use the house freezer and then do three tempers, with the freezer between them.
What HRC did you get at that?If you are concerned about RA you can also use a lower austenetizing temperture.
With 14C28N coupons I reached same hardness with freezer and cryo when using a 1900°F austenetizing temperture.
