Larrin said:It should be pretty close, though I'd take 154-CM for it's stainlessness.
Don't be retarded.Cobalt said:by you standards they would be the same steelI mean, really, there are only minute differences in both:yawn:
Hair said:D2 is nearly as stainless as 154CM.
joeyabs81 said:Between 154CM and D2, which of the two has better overall edge retention?
Larrin said:Don't be retarded.
154CM and D2 have similar max hardness and D2 has a much higher wear resistance, thus they will be similar on some cutting and D2 will have an advantage on others, so unless corrosive materials are cut D2 is likely the better cutting steel assuming both are heat treated for optimal hardness / wear resitance.
-Cliff
STR said:According to what I've been told and CPMs data on the two steels 154CM has a slightly higher wear resistance to D2 :
