VG-10 is a Japanese steel with good all around properties. Complaints are
few on this blade. It sharpens easy, holds a pleasing edge retention, has
decent corrosion resistance, and buffs to a gorgeous shine. VG-10 is a
high carbon stainless steel, similar to 154CM ... Spyderco has performed
testing which show VG-10 to be superior to ATS-34/55 in corrosion
resistance, better initial sharpness and edge retention, and superior to S30V
in terms of corrosion resistance, but lower in edge retention. VG-10 is a
high wear stainless steel in the same class as 154CM, however has better
edge stability and offers superior corrosion resistance and extended edge
retention. Contains chromium that aids in rust resistance and high carbon
that provides exemplarily edge retention and ease of sharpening. Is
considered Super Steel. Most people seem to consider VG-10 to be one
of the top-tier knife steels. It won't win every category, but it does pretty
well in all of them. I don't know anyone who doesn't think its a high quality
steel, though. Although there are some real "steel snobs" out there, my
experience is that a decent knife made in VG-10, S30V, ATS-34, 154CM, or
D2 (along with a few others) will perform "close enough" that in day-to-day
use it's of small concern which one it is made out of. Each steel has some
areas where it may do slightly better than others, and each will have some
areas where it will do slightly less, but any of them will generally work just
fine. Rockwell hardness range found: 59-62.
W-1: Most popular, least expensive and versatile tool steel (not a stainless
steel). Has high carbon content and is a fine grained electric furnace melted
commercial tool steel.
W-2 Tool steel, not stainless steel. Shallow hardening, rather weak, and
make durable knives only if held below 54 HRC (hardness, Rockwell Cscale).
Rusts very easily due to the lack of chrome and vanadium. Only
alloying elements are carbon and manganese. Usually used in industry for
inexpensive, low yield tooling.
X15TN or X-15 T.N. or X15 T.N or X15 - A French steel. [Benchmade
marketing hype: This French steel was developed for the aircraft industry for
jet ball bearings, as well as the medical industry for scalpels. It has the
ability to resist rust in the worst of conditions while maintaining ample edge
retention. The capability behind this steel is in the way it is manufactured,
resulting in the finest steel for use in harsh environments such as salt water.
The edge on an X15 T.N blade is easier to maintain.] [Boker marketing
hype: "X15 TN blade steel boasts an HRC of 58, with cutting power of 440C
or ATS-34. A virtually rust proof stainless steel with good edge retention.]
[Opinion: X15 is along the lines of 440A
Boker is hyping that X-15 is
being close to ATS-34. That's a big diffeence from 440A.] Have not found
much information on this steel.
ZDP-189: The next super steel is ZDP-189, This steel is incredible in edge
holding and hardness. The heat treating process for this steel is a guarded
secret. In tests conducted by Blade magazine ZDP-189 out performed VG-
10 by a factor of 10X. But cost is about 20X higher than VG-10. I have
noticed ZDP-189 will not take a super sharp edge like VG-10 or AUS-8 steel
will. That does not mean it won't take a good edge; the factory edge would
shave hair easily but when you run a finger over the edge it feels toothy and
slightly rough. ZDP-189 under this magnification shows a very angular
structure as compaired to VG-10. A potentially very hard stainless steel
(Hardenable to a very hard 67-68 on the Rockwell hardness scale) has less
brittleness than usually accompanies such a hard steel. The high hardness
and carbide content results in superior edge retention in abrasive situations.
Often laminated with tougher steels. ZDP-189 is a steel that has unusually
amazing edge retention and it has been measured as high as a 69 HRC.
While it is a cutting steel and will chip, it is not as brittle as one would
presume for such a hard steel. Manufactured by Hitachi in Japan. "It's like
the Ferrari or Lamborghini of blade steels." ZDP-189 is a powder
metallurgy martensitic stainless steel made by Hitachi Metals. ZDP-189 is
mainly promoted for the very high hardness 66/67 HRC which is rare in
staniless steels
Angles for Sharpening: From web: Edge angles [per side, not inclusive] can
vary from 10° to 40° , but most are between 15° (filet knives) and 30°
(survival knives). Different angles are suited for different tasks. What's
suitable in the kitchen will not do for camping. Twenty degrees [per side] is
about right for kitchen knives, twenty two [per side] degrees is good for
pocket knives, and twenty five degrees [per side] gives a long lasting edge to
a camp knife. Use circular strokes until the old scratch pattern is gone.
According to Lansky: 20° [per side]: A commonly used angle for higher
grade, quality blades. Provides an excellent edge for these types of knives.
Ideal for kitchen knives. 25° [per side]: The recommended angle for most
knives that need a durable, sharp edge. Ideal for hunting and outdoor knives.
30° [per side]: An outstanding angle for knives that see the heavy use of
cutting cardboard or carpets. Only for heavy duty use. You're less likely to
chip S30V if you don't go lower than 30° (inclusive; or 15° per side) when
sharpening. Going to 40° (inclusive; or 20 per side) will let you take even
more advantage of its insane wear resistance, but you'll need more force to
cut. The Spyderco Sharpmaker only has two angles: 30° inclusive
(15°/side) and 40° inclusive (20° per side), and generally people will use the
30° to shape the edge and the 40° to set a microbevel. Sal (CEO of
Spyderco) says he sharpens all his knives at 30° [inclusive; 15° side].
Sebenza web site recommends a 40° [inclusive; 20° side] edge on their
knives. NOTE: Ceramic stick-type sharpeners (such as the Sharpmaker)
tend to refer to inclusive angles; clamp-style sharpeners (such as the Lansky)
often reference single-side angles.
Comparisons:
I think Joe Talmadge explains the relative properties pretty well. (editors
note: Strength refers to edge roll resistance and toughness refers to chipping
and cracking resistance.) To Quote: ATS-34/154CM, VG-10, and S60V are
the next group up. It's difficult to make generalizations about ATS-34 and
154-CM -- they are in such widespread use that heat treat varies widely.
These steels provide a high-end performance benchmark for stainless steels,
and hold an edge well, and are tough enough for many uses (though not on
par with good non-stainlesses). They aren't very stain resistant, however.
VG-10 can be thought of as being like ATS-34 and 154-CM, but doing just
about everything a hair better. It's a little more stain resistant, tougher, holds
an edge a little better. And VG-10 has vanadium in it, it's fine-grained and
takes the best edge of this group. S60V has by far the best wear resistance of
the group, though consensus is becoming that it should be left around the
same hardness as 440C (56ish Rc), which means it will be relatively weak
compared to ATS-34, 154-CM, and VG-10, and so it will indent and lose its
edge quickly when strength is required. BG-42, S90V, and S30V constitute
the next group up. BG-42 has better wear resistance than all the previous
steels except for S60V. It is tougher than ATS-34, and more stain resistant.
It is wear resistant to the point where it can be difficult to sharpen. S90V
represents the ultimate in wear resistance in the steels discussed so far. Also
tougher than ATS-34, and more stain resistant. It can be very difficult to put
an edge on. It is difficult enough to machine than it is used almost
exclusively in custom knives, not production knives. In your buying
decisions, you might want to take into account the difficulty of sharpening
these steels. S30V backs off on the wear resistance of S90V, but is
significantly tougher and easier to sharpen. It is more wear resistant than
BG-42. The jury is still out, but it may end up this week's ultimate high-end
all-around stainless steel, due to high performance coupled with easier
machinability and sharpenability than the other steels in this class.
Some Sources (not a complete list):
http://members.home.nl/b.ollivier/html/SteelChart.htm
http://spyderco.com/forums/
http://users.ameritech.net/knives/steels.htm
http://www.benchmade.com/about_knives/our_blades.asp
http://www.bladeforums.com/
http://www.cutleryscience.com/
http://www.edgedconnection.com/bladesteels.html
http://www.internetarmory.com/knives.htm
http://www.knifeart.com/steelfaqbyjo.html
http://www.matweb.com/
http://www.seamountknifeworks.com/article6.htm
http://www.sff.net/people/pff/steel.txt
http://www.warrenknives.com/blade steels.htm
