Chefs may not know better but butchers do and they do use steels to touch up their blades.I agree with tabeeb - steeling is nothing you should do with any decent knife, regardless of the edge grind. There are so many better ways to keep a knife sharp, or bring back an edge, than steeling. Just cuz chefs who don't know any better do it, does not mean you should!
Learn ot use a strop - it's the best you can do for any edge grind! Keeps a sharp knife sharp!
I worked in a meat packing plant for 20 years and we used steels but they were smooth as glass.
That's a heck of a lot better than the grooved ones that come with the standard kitchen knife set.
Personally, I think stropping is better yet, even on plain leather without compound.
YMMV
YMMV
My understanding is that a steel re-aligns a knife edge, making it sharper, but that steeling isn't considered "sharpening".The steel does a great job of raising a wire edge. The stropping just removes that. It works wonderfully.
Andy
You are correct sir. Steeling a blade only realigns the edge. Butchers will steel a blade to extend the cutting session until having to hone. Boning and fillet knives are thin and will eventually roll when hitting a bone, hard fish scale or table etc. Since the material being cut is always the same (flesh), you can get away with steeling for awhile. A rolled edge will snag and tear. You can feel it. Old timers don't even look at the blade. They just steel the blade when they feel it hanging up. A good trick is to remember which side of the blade got the last swipe of the steel. If it's still snagging, steel again and make the last swipe on the other side of the blade.My understanding is that a steel re-aligns a knife edge, making it sharper, but that steeling isn't considered "sharpening".
Raising a wire edge, or burr, is part of the sharpening process, indicating the extreme edge has been reached.
I usually remove the burr by stroking the hone at a slightly higher angle than that which raised it, but I've heard they can also be removed by stropping. I would think a hone would remove a burr much quicker than a strop, but I haven't tested that so can't be sure.
smegs-- Thanks for the good info and confirming that I'm on the right track with my thinking.
Andrew Colglazier-- I tend to define words and terms the same as the majority of people on the forum. This helps to keep confusion and misunderstanding, which seems to occur more often with knife sharpening than a lot of other fields, to a minimum.
Since steeling doesn't sharpen (using the most common definition of the word) I have to wonder if you are really creating a wire edge (as you do with your belt grinder) by steeling, or just moving weakened metal around.
But the bottom line is if it works for you.
