- Dec 10, 2006
When steeling a knife does anyone have advice on what to use? I see normal steels that can be found for knives, mostly kitchen knives, but are there any other options? When it comes to sharpening systems I know we are spoiled for choice, but hearing Mr. Schempp talk about steeling a edge such as VG10 to maintain the edge rather then using stones to take of metal got me interested in this method. Any advice will be appreciated. Thanks in advance.
Only information I found on Steeling:
Steeling helps maintain sharpness. This process realigns the edge, correcting for dulling causes such as a rolled edge. A sharpening steel is a type of hardened cylindrical rod used similarly to honing stones. For example, a butcher steel is a round file with the teeth running the long way, while a packer steel (used in the meat packer's industry) is a smooth, polished steel rod designed for straightening the turned edge of a knife, and is also useful for burnishing a newly finished edge. Because steels have a small diameter they exert high local pressure, and therefore affect the knife metal when used with very little force. They are intended for mild steel knives that are steeled several times a day, but are not well suited for today's tougher and harder steels.
