- Jun 29, 1999
I've never really used a steel until recently, when I acquired a burnisher (Rc 64+) for that purpose. It's basically a steel rod, mirror polished, and very hard. The other day I was using my CS Voyager tanto around the yard, cutting up fallen branches, trimming the tomatoes, opening the mail, cutting tomatoes and veggies. By the end of the day the edge, still sharp (AUS8 is good stuff, IMHO), felt a little ragged, so I pulled it lightly across the steel at a 90 degree angle both sides two or three times... and the hair popping edge came back! Note that this technique is a bit different than whisking the edge lengthwise along the steel as you may have seen some show-off chefs perform. A long-time knife vendor in Edmonton advises that the right way is to pull it lightly across the steel at a right angle, which gives you better control of the angle. It works.
