Steels to make blades from
what should i use to make a knife that i would be able to heat treat it and temper it i am a beginer and 13 so i need somthing cheap
also on a side note : what would i use to put a first edge on a knife and the grind angle?
Welcome to the forums. Probably the easiest steel to start with, if you are doing all those things yourself, is O1. It is also one of the cheapest. If you search this forum, you'll find all sorts of posts and links to tutorials and some very good books on the subject.
As a starting thought, I'd say start removing steel with whatever you have. A grining wheel - a side grinder - a sanding disc on an electric drill. From those rough beginnings, a belt sander is the best to get it to where you want it but draw filing will work very well too.
Many makers start with a kit and assemble it. Then they make a blade and have it heat treated professionally - and bit by bit they add to their skill set. It's easier to experience success in small steps.
Bets of luck (you'll need that too)
Rob!
How are measurments displayed width/thickness or thickness/width? Also what is the avrage cost for steel? (steel that i will temper and heat treat it to hold a sharp edge)
