- Apr 19, 1999
I got my hands on a piece of this material about a week ago to evaluate for possible inclusion in my line and got around to grinding it today.
I love this stuff, it grinds well with a sharp aluminum oxide belt, finishes quickly with 240 grit greaseless compound and polishes to a near mirror with a 400 grit cork belt followed by a quick buff with green stainless steel cut and colour compound. The finish as I said is near mirror with a touch of softness to it caused by the grain structure of the metal, probably best described as a semi gloss finish. Drilling goes very quickly with a carbide twist drill and a little slower with a carbide spade drill but it drills cleanly.
I have decided to mount double bolsters of polished damasteel and acid etch the entire blade with the bolsters attached after assembly because a test showed that the blade is unaffected by the muriatic acid. Neutralizing the acid afterwards will take a day or so to let the baking soda solution soak under the bolsters. Scales will probably be mastodon.
I will post a scan when it is finished.
