Stellite?
ok, simple question. what is this new steel that i have just started to see being mentioned on the forums? whats it like, what sort of edge does it take, ect ect?
I realize the question is about stellite, but that and Talonite are pretty much the same thing.
"Talonite"
by Chuck Bybee
Why Talonite Cuts so Well - Lubricity
Talonite® is much slicker than steels so it wears much longer. Talonite® has outlasted 6K by 35% in wear tests. These were wear tests in a cereal manufacturing plant. The abrasive substance was organic fibers in corn and wheat. Talonite® rates much higher than steel and much closer to diamond or Teflon in slickness. Talonite® is slicker so it also cuts faster and easier. Machinery's Handbook, 24th Edition says that these alloys can be run 20% to 50% faster than high-speed steels when cutting.
Corrosion Resistance
The development of high speed and high temperature turbines for jet engines led to the development of a new Haynes alloy. A good way to understand the corrosion resistance of Talonite® is to think of a Navy fighter that sucks sand into the engine flying out of Pensacola and sucks seawater in landing on a carrier. Talonite® is used regularly in applications such as sawing green lumber in a sawmill. Highly corrosive organic acids, high heat from friction and cut lengths of millions of inches as well as interrupted cuts and intense thermal cycles, (extremely hot in the cut and out into flood coolant). Talonite® makes an excellent dive knife. It does not rust by the usual definitions, however it is technically susceptible to chemical attack. Generally it requires something on the order of boiling 20% acid solution such as hydrochloric acid or sulfuric acid for weeks or months. Talonite® was developed for rough environments. If your instruments were really good you might detect corrosion in salt water after a thousand years.
Talonite Compared To Steel
Talonite® is an alloy that is primarily cobalt and chrome with only a very small percent of iron in it. Steel is iron with a very little bit of carbon in it. (Iron with .1 - .3% carbon and a maximum of about 2.5%). Talonite® is very different than steel and cannot be compared one to one with steels. Talonite® has a lower Rockwell than some steels but it contains carbide grains. It is softer on a Rockwell test but much more wear resistant than steels. In addition to the hardness of the carbides it also has about a 30% greater lubricity. Talonite® can be sharpened to a razor edge as well as any other material, however it will cut much better than other materials with an equivalent edge because it is much slicker. Steels have a greater tendency to grab in the cut. The grabbing creates more work and dulls the edge faster.
Talonite Is Expensive
It is a performance alloy first, last and always. It was developed to withstand tremendous abuse in jet engines and other applications. Jet engine turbine blades have to keep an exact edge no matter what gets sucked in. Even the wear from air passing over them is more than a knife will ever see. This alloy was designed without cost in mind. Fortunately it is such an excellent alloy that the demand has brought the price down but it is still about $200 a pound. Even though Talonite is 20, 50, 100 times as expensive as steel it is so popular that the big problem has been getting enough of it made. There is only one plant in the world that is precise enough to make alloy this good.
Talonite Is Hard To Work
It takes more time and material to make a knife with Talonite as it does with other materials. Talonite is very wear resistant when being shaped to make a knife. Talonite knives sell for more than knives in lesser materials. However Talonite knives are so good that they are a bargain even at these prices.
Best Regards,
STeven Garsson
-It's not new, it's been around for many years
-it's not steel, there's no iron in it
-it does some things better than anything else
-it does some things worse than anything else
-it's expensive
-a good all arounder it aint
-I know, I have one
i've heard ya should never pry with a talonite blade they snap easier than steel FWIW.
i have a talonite ralph maxx and i suppose its 'ok' but i dont know that its really any better than a good steel.
imho it doesnt hold an edge as good as a decent steel ie 154CM or S30V.
its real good as far as corrosion goes.
when i 1st started collecting knives (circa '99) talonite was the bomb and a lot of folks were making knives with talonite blades, ya hardly ever see anything new with it nowadays.
Razor you had better get an email off to Kellog's , they use stellite blade to cut each and every cornflake to an accurate thickness.
They could be poisoning us all.
LOL!
Good one George!
There is SO much misinformation on these forums sometimes.
What is scary is that some of these people vote!
