Been making knives for awhile...only recently have I gotten a stencil and associated gadgetry. At first I was so ignorant about the process I did not know that you etch on DC, then darken on AC. My etcher is a second hand model that is variable in the current applied to the blade and it does seem to work OK..I think the problem is with me. In an earlier post I was asking about how to actually pull this etching thing off, as I was having diffuculty even after reading the instructions. I had many suggestions that I was/am very appreciative for.
Basically, most folks told me to etch on DC by placing the stencil on the blade, pad wet (but not "soaked") with etching solution and touch it to the blade for a count of, say three, and then take it off the blade...and do another "three count" for about two more times. The intent was to NOT cook the dern thing by leaving it on there for longer periods of time, but numerous shorter intervals. Then do the darkening on AC using the same series of three or so markings at about 3 seconds each.
Problem: I am getting a smoky haze around my etching after this process that makes the blade look like crap afterwards...really disheartening after all that work on a finished knife. The etcher is, like I said, a variable intensity (or whatever you want to call it) model and I turned it back to about 60% of full power and it still "smokes it up". Thought that might help, but it does not. I used to put a drop of etching fluid on the blade before laying the stencil on top of it...not a good idea either. Now etching on a dry stencil with the damp pad...no better. I have no idea whether I am smoking things up on the etching part or the darkening part, but I about to pull my hair out on this one. To get the haze off the blade, I have to polish ever so lightly with a non abrasive polish and the dang stuff takes off the darkened image, leaving a clear outline of the etched image...looks like crap. And, yes, I am using the proper etching fluid for stainless steel on my 440 and 36 blades.
What am I doing wrong? I am experimenting but just can't find the right combination of intensity and number of strikes...any help is appreciated!
Thanks and happy holidays.
