Not quite sure what all the resistance is about.
The thumb studs look like blade stops because they ARE blade stops.
The knife in question (ZT 0350) has SpeedsSafe, the Skyline does not.
I do not personally have a Skyline, so I will not argue the efficacy of it's blade stops as thumb studs.
Having SpeedSafe means that knives with thumb studs as blade stops only need to be pushed open to about 30º before the assist takes over. This in turn means that if done properly, the knife can open effectively using the thumb studs only taking full advantage of the assist.
No one is saying that you should not use the flipper, just that the thumb studs should not be written off as unusable for opening the knife. Personally, if a knife has a flipper, I like to use that. It is always nice to know other methods of deploying a blade though.
I made a video (HD) to show that the thumb studs work quite well to open the 0350 and the 0301.
[video=vimeo;26745964]http://www.vimeo.com/26745964[/video]
Now that you've hopefully watched the video, if you have either knife, please just try the technique (do so at your own risk, since I cannot even guess at your competency with a knife
If you can flip a coin, you should be able to do this.
I hope that this helps clear up any confusion about whether or not the 0350 opens well with the studs.
