Crinking, definitely. No need for the knife to be thicker than necessary imho.
Which do you prefer? I believe all of Case's are 2 spring now except for the 6347 pattern. Buck uses all 3 spring designs, I believe. To crink or not to crink, that is the question.![]()
Elliot,
Thanks.
Is there a term when the blades are ground to one side to make them thinner so you need less crinking?
I have a small H&R that the side grinding is very well done and makes for an even thinner profile
I believe that that is called "asymmetrical grinding". If you look at Queen stockman patterns you will see it and also Victorinox knives. It allows the "crinks" to be more subtle so the blades do not have that "bent" appearance yet they still fall past each other.
I don't think Case makes a 6347 anymore do they? I have a boatload of older 6347's and they are all two spring knives. Even the ones that have 3 blades plus a punch still only two springs.
