"Stockman" vs "Cattleman Clarification, Please?
afishhunter
Basic Member
Is the difference between the "Stockman" and "Cattleman" ONLY the blade combination: Pen blade on the "Cattleman" vs Spey on the "Stockman"?
Is a "Cattleman" ALWAYS on a equal end/cigar frame, or can they be a Serpentine frame, like the "Stockman"?
Reason for confusion:
My Ka-Bar 1109. Serpentine frame, BUT it has a Pen blade, not a Spey.
Is the 1109 a "Stockman" or because of the pen blade, a "Cattleman's" knife?
I don't want to misidentify it.
Yes. I am aware most "Cattlemen" have a Spear Point primary blade. However, I have seen a couple (in a equal end cigar frame) with a clip point blade.
I'll just say that there is a lot of "fluidity" when it comes to some definitions. (Even when using the old "Levine's" as my go-to source.)
I used to be more rigid in my thoughts on patterns. I've mellowed with age (some).
Levine's 4th Ed. notes that the Stockman is on a Serpentine frame. He also states that "at least 90% of cattle knives are equal-ended" -- "but, a few have been made in other shapes", which include: Premier (or Serpentine), Eureka (or Swell-Center Serpentine), Balloon, Jumbo, Canoe, and Surveyor.
Exactly. (Fodder for food fights.) ☺️
Just found out Ka-Bar called it a "Small Stockman"
a) If 4 inch closed is a "SMALL" ... how big were their "Medium"; "Large" and "Extra Large" stockman? (and what were the model numbers so I can try to find them?)
b) Since the manufacturer called it a "Stockman" (and a "small" one, at that!🙄) I suppose they MIGHT have named it right ... despite the "small" designator.🤔🙄
The box says Rail Splitter
This one too is a Rail Splitter
but I've seen them referred to as Surveyor, Swell Center, and others mentioned above.
GEC calls these Stockman but to me they are closer to being a Cattle knife.
As mentioned above, blade configuration isn't written in stone for either a cattle knife or stockman knife.
Nice knives, Ed!! I agree - your Tidioutes are Cattle knives!!!
Interestingly, your Rail Splitters are referred to as "Surveyor's" knives, by Bernie Levine!!View attachment 2500543
Remingtom Surveyor!!
Yep, you're right Charlie waynorth waynorth . I remember some years ago that Elliott Blues Blues and I had a lengthy back and forth about Surveyor/Rail Splitter when the BF knife came out in I think 2010.
Huh, I always thought the main difference, aside from the serpentine pattern, was that a "stock knife" or "cattle knife" had a spear point as the primary blade while "stockman" knives had some variety of clip point main.
Names get used by advertisers, collectors and general-public leading to a 'fluidity'...I assumed that Cattle knife was the older term and were EE patterns and generally larger knives, Stockman being serpentine and in various sizes and both styles having a variety of blades/implements. Then I looked at my CASE Humpback Stockman...not swell-centre exactly... EE yes but not the usual Cigar shape (the frame is almost the same size as the CASE/Bose Norfolk, both have fully sunk-joints) But CASE call it a Stockman so...Humpback Cattle Knife might sound odd.... ;) Yet there are of course breeds of Humpbacked Cattle .....Then I'm proposing Zebu Knife as the definition
All these knives are Stocknives but not all are Cattle...or Zebu!
I found this info from Levine to provide some interesting context for cattle vs. stock knives:
"As the name suggests, the cattle knife was designed for work on and around livestock. The type seems to have been introduced in about the 1870's."
"The premium stock pattern [a serpentine-shaped double-end pocketknife that ordinarily has two springs and three blades] was introduced about 1890 as a less bulky and more dressy version of the cattle knife. The stock knife was designed as a rancher's pattern, so it was at first marketed mainly in the West."
