cool thanks for the info! I'm hoping to get my first HT oven in the next few months so any feedback on this purchase would be appreciated, I'm sure others can benefit as well.The old and new are both 220, and the old was far from slow to heat up, but was very limited in length and number of blanks.
The biggest issue for me other than length is the footprint, and castor stand this one sits on. I can roll it out of the way when not in use so it doesn’t permanently take up a benchtop or large rolling cart space. There are a LOT of coils in this compared to the old so I am hoping for quick ramps.
I have their 30” model and it does ramp fast, usually I’m at temps in 20-30 minutes, carbon steel temps closer to 20 stainless temps closer to 30. They do have a smaller 120v model but I’d expect it to ramp closer due to voltage similar to any 120v kilns I’ve seen or used.The old and new are both 220, and the old was far from slow to heat up, but was very limited in length and number of blanks.
I don’t typically work with steels that I need to use foil, most of the time for stainless I use nitro-v and I can use anti scale for that and then plate or oil quench. If I was doing a bunch with foil packets I’d have to figure out the best method for holding them. But personally the anti scale coatings work better for my process.Ah that's a good point you make Joshua - the vertical air baths would be as ideal for alloy blades that need a foil wrap and plate quench correct?
I like that thought better than the spring idea. I could just picture me trying to lean down in the lava hole and fish a bright orange steel packet out of thereIt seems like all you would need to do is fold the end of the packet over a stainless rod and hang the rod on two of the ceramic rods.
Tried this yesterday, worked very well.It seems like all you would need to do is fold the end of the packet over a stainless rod and hang the rod on two of the ceramic rods.
