Just curious,why don't you favor the abrasive erasers?Erasers are OK and can do pretty well, if you use them after each use of your ceramic hones. If you neglect them too long, the heavier/deeper accumulation of swarf won't be removed adequately with an 'eraser' of any kind. The 'rust erasers' are usually a silicon carbide grit embedded in a rubbery matrix. I tend to avoid using those anyway, for the most part. I'd rather use a simple pink eraser for the per-use wipedowns. I use those about 99% of the time, after each use of my ceramic hones. If you stay ahead of it this way, you'll possibly never need to do anything else.
For heavier accumulation of swarf on ceramics, the already mentioned Bar Keepers Friend powder, mixed to a paste with water, works well to dissolve the swarf. It'll leave the ceramic cleaner than any other method, save for complete abrading and resurfacing of the ceramic itself. But resurfacing isn't needed unless or until the ceramic grit becomes too worn/glazed to function anymore.
I've found them not to be any more effective than the simple pink erasers, and even less effective at times.Just curious,why don't you favor the abrasive erasers?
Search for the "King Nagura" on Amazon, or search for the "Bodrid" stone on Gritomatic.What stones exactly?
And what eraser?
Please be more specific.
The idahone super eraser is what I mean spefically here since that cost 16$ and it usual used for sharpen rods.I know what those products are and I'm well versed in cleaning/leveling stones but the stone type has not been mentioned nor has the specific product the OP was referring to.
Unless it's that expensive due to where you might be living (are you outside the U.S.?), you might want to shop around or recheck per-unit pricing. Looking online, it seems most of them are priced in the U.S. at around $5 - $6 each. Many are sold in packages of either 2 or 4, priced around $12 - $25 for the bundled package - so hopefully, the $16 price tag pays for at least a couple of them.The idahone super eraser is what I mean spefically here since that cost 16$ and it usual used for sharpen rods.
Ah, sintered ceramic stone. (see below)The idahone super eraser is what I mean spefically here since that cost 16$ and it usual used for sharpen rods.
Same.I have used all of the above, but I have had the best success with the bar keepers friend mixed in to a paste and using a green scouring pad to apply it. Try it ,it works
