- Oct 7, 2009
I want to begin building a set of high quality, versitile stones with the capability to do everything from reprofileing to fine polishing. Right now, i'm considering placing an order for a set of DMT Dia-sharp continuous plates in EC, C, F, and EF. I was going to spring for the more versitile 8" length, but I'm tempted by the highly economical 6" double sided plates. I might try some carbon steel knives on these stones, but I'm primarily buying them to use with S30V folding knives. Sooner or later my plan is to expand my collection with the Shapton Glass stones which range up to an incredible 30,000 grit!
My first question is: will the 6" DMT plates be of adequate length and composition to maintain flatness with a collection of Shapton stones? Question 2: Which Shapton would best pick up where the DMT Extra Fine left off? (I've considered the DMT EEF, but I don't see the point of the added expense when I know I want to finish with ceramic anyway.) Question 3: Should I skip the DMT plates all together and invest in a full set of Shaptons beginning with the 220 grit glass stone? (I am attracted by the fact that Shaptons offer such a wide range of grits in a single type of stone, as I would like to avoid a hodge-podge of different stone types as much as possible.) Is there an advantage to having the diamond plates on the lower side of the grit range instead of all ceramic with a single leveling plate?
Ok, I think thats everything I had in mind for the time being. I'm open to all suggestions and eager to learn. Thanks.
