Two questions for the gang to help me with if you could please.
I have a stone that I inherited from a friend of mine, a Native Canadian carver who used this to sharpen all his small detail knives to an unbelieveable edge. I have found that it seems to put a better final edge than my Sharpmaker UF stones if I use it after them. Does any body know what kind of stone (grit or brand) this is by the picture/colour? There are no identifying marks on it or the holder (which was homemade). The stone is approx. 2 x 4 3/4 inches. Can anyone identify it as to the grit, brand or type?
Next question. I have a standard Lee Valley 2- sided leather strop, one side is loaded with green stick compound which I initially crayoned on, the tried to put it on after softening it significantly with a hair dryer. It is now loaded unevenly across the surface, and there seems to be one dime sized spot where the compound does not want to stick to.
So should I clean it off and start over, and if so, how do I remove the old compound, or should I just give up on that side and use the other side, and how can I apply it more evenly this time?
Thanks to all that can help,
Rik
Rik
