I have a $5 fine arkansaw natural stone and i am thinking of getting something better . I do have a few conditions
-need to be able to make a knife scarry sharp (i have some experiance sharping)
-under $20
Any help would be appreciated
Look for Japanese Water Stones, I got 400/1000 grit and 1000/6000 grit
then polish on a Starkie Sharp which is really a leather strop.
Get Green and White polishing pastes and you can use both sides of a belt to polish your edge!
I got mine here :-
Try using wet/dry sandpaper. I find it works very quickly. I use a sheet of 120 grit aluminum oxide for reprofiling, then 400 wet/dry, then 1500, and finally some stropping with noxon. It's very quick. I did a blade on my D2 knives in about 5 minutes with this. Stones took 20 minutes for reprofiling alone.
Mmh not so easy. I found that you need at least two different grits to get a good edge (one to true the edge, one to polish it). One stone under $20 is certainly possible, but two under $20 is pretty difficult. For the Japanese water stones, as much as I love them, you need the means to flatten them, which adds cost.
Spyderco's double stuff you can get for about $21. The #1000/#6000 King stone you can get for $27 from www.bladegallery.com.
But really I would suggest to save up for twice as long and get a Spyderco Sharpmaker. Considering, that it comes with two grits its $40 translate to about $20 per stone.
Sandpaper is also not a bad idea, but I tend to think that in the long run they are going to cost you actually more than a stone.
