- Mar 17, 2015
Sometime ago, I read a thread about how someone stonewashed their CRK. I couldn't find the thread, so I decided to do a step-by-step, with an easy-to-remember thread name. This was my first time trying to stonewash, so please add your experiences, what you did differently, suggestions etc.
Since this was my first time taking a Sebenza apart, I took a picture so I could reassemble it properly.
Here are the things that I used to prepare the slabs.
https://i.imgur.com/MwJ7Wj5.png
I put tape over the lock face and detent ball.
https://i.imgur.com/xwsJ0qG.png
Since I didn't want to stonewash the insides of the scales, they needed to be screwed together. I didn't want to tumble the CRK hardware, so I used these screws (as shown in picture #2 above).
https://i.imgur.com/16CqLvE.png
To avoid risking damage to the threads behind the pocket clip, I jammed some Poster Tack in there. It kept debris out of the threads and was easy to remove after the stonewash. If you don't have Poster Tack, you could use Plumbers Putty, Silly Putty...anything pliable and removable.
https://i.imgur.com/bZqDcr1.png
Here's the stonewash "media" that I used: a bunch of pebbles, various nuts and a couple of brass cases (because I'm curious like a cat).
https://i.imgur.com/VM4KH98.png
The stonewash media, scales and pocket clip were all tossed into a plastic container (I did this dry, no water or oil)...I shook and tumbled it by hand for a while. I know others have put it in the clothes dryer, but I wanted to check it every couple of minutes to evaluate the progress.
https://i.imgur.com/g49a5rr.png
I didn't watch the time, but I probably agitated it for 10 to 15 minutes. After I was happy with the look, I wiped it off then put it in another container with stainless steel pins (you can find these wherever reloading supplies are sold). I shook it in here for a short amount of time, probably two minutes. This burnished it somewhat. Also, after this step, the pocket clip seemed to match the scales better.
https://i.imgur.com/TUkJF8o.png
Here are a few pictures right out of the stonewash, and reassembled.
https://i.imgur.com/zlYvzQM.png
https://i.imgur.com/qrdzg7B.png
https://i.imgur.com/rK61Oxl.png
Notice that since it didn't get tumbled with the scales, the CRK hardware is factory-shiny.
...and here are a couple of side-by-side pictures with an untreated CRK.
https://i.imgur.com/rKzEGMc.png
https://i.imgur
Again, this was my first crack at stonewashing. If you've done it differently or have suggestions, please chime in. And please post pics of your stonewashed or Scotch-Brite treated CRK's.
-Sean-
https://i.imgur
-Sean-
