So I have been struggling the past few weeks with a few of my knives that have a very tiny (and I mean ever so slight) vertical blade play, known commonly as Lock Rock. I originally thought I could get over it, but couldn't, it's eating my brain.
I set off first on finding the cause and I believe that it is excessive tolerance between the linerlock and the stop pin. I stuck a very small slice of post-it note paper onto the stop pin, opened up my knife as I normally would, and there it was, the perfect lock up. Rock Solid in all directions. The first thing that came to mind was, a bigger stop pin would be the solution here. However, I do not have capability to make one or know where to order one for this particular knife, Civivi Governor.
I started experimenting and came up with a fairly good solution that uses super glue and a rubber band. It is not pretty, but it got the job done. I dropped a dab of super glue onto the stop pin and stuck a rubber band ontop. Once it was fully dried, I peeled back the rubber band and was left with a nice rubber coated stop area on the pin. Opened the knife a couple of times, and that was it, perfect lock up. The rubber layer on the stop pin deflects when the knife is opened and it takes up all the excess tolerance between the lock and the stop pin. This whole thing is also reversable with a little bit of acetone, so it was worth a shot.
