- Sep 24, 2008
I was wondering what you guys prefer for a blade stop on your folding knives? Do you like the stop pin, or do you like the idea of the thumb lugs doubling as the stopper also. What are some pros and cons?
I'll take both.
Although the thumbstud stop is pretty much the only option if the blade has a flipper, otherwise that flipper wouldn't be able to clear a stop pin.
I hate to ask a silly question but would someone give an example of common knives that use these different methods. In terms of maybe a Benchmade or a Spyderco - something like that? Thanks!![]()
Stop pin. I don't like thumb studs smacking against the handles. Plus, I would think that there's a greater chance of thumb studs breaking off than a blade tang pushing against a stop pin and tearing it through the liners.
That might be the case for thumbstuds that aren't solid pieces. I'm not sure which ones are which. The only one I know about is the XM-18 and the thumbstud/stop pin is one solid piece on that.
Whether the thumbstuds act as a stop pin or there's a separate stop pin, the impact should be about the same.
I don't think any are solid pieces. As far as I know, most thumbstuds are threaded in some way or fashion. You have two separate thumbstud halves. In between them lies a threaded rod that connects both halves. Sometimes that threaded rod is part of one of those halves. Other times, the threaded rod is separate, and when you thread both halves on the rod, turning each half in opposite directions tightens down both halves tremendously.
...The blade locks up on the solid ¼ in dia. thumb stud which is press fitted into the blade. This makes for a very strong lockup as there is no loosening of the thumb stud which can happen with two piece thumb studs, and it is a solid bar....
Images courtesy of knifeworks.
I stand corrected.Just for clarity because you said you don't think "any" are solid pieces, according to Rick, the XM-18 definitely has one solid piece for the stop pin.
From his site:
