I need a storage solution.i have a dresser full and other I just put in a bin. Once a year or so I go through and oil.I have knife rolls also it's a pain oiling so many knives.Im selling some to thin them out,In the dresser I have them rolled in old t shirts.I was thinking about some type of tool chest with drawers.Thank you all very much this is a great site
This is the best solution to your storage without buying a heavy safe that is bolted to the ground. This will cost you 150-170 dollars.
http://www.ebay.com/itm/HARDIGG-IND...643?pt=LH_DefaultDomain_0&hash=item460fb9cd2b
This is what recommend to use. Waterproof, durable, and air tight.*** For all storage of outdoor gear and valuables. The foam can be cut with any serrated kitchen knife to your needs, removed as well. slits can be cut in the foam in the lid and bottom foam to insert flashlights (AAA Maglights), tools (Wrenches), and small knives. VERY durable case, completely waterproof, THICK plastic, secure metal clasps. The only thing missing is a way to lock the box up;
http://www.homedepot.com/p/National...-112-U-BOLT-SS/204701451?N=5yc1vZc26wZ1z0ydp7
***Just two sets of these; drill holes, use modified U bolt trailer plates and lots of gorilla glue/two part epoxy (the trailer plate to the box) for a master lock. Place where ever you would like on the box for the best convenience and security.
http://www.galaxyarmynavy.com/prodimages/large/10044.jpg
DESSICANT*** Use at least 60-100grams, this will repel water and keep your box moisture free.
http://www.ebay.com/itm/Gun-Safe-Re...Dri-2-Desiccant-60-cu-ft-Dakota-/230955640098
You metal goods are secure, easily moveable, moisture and air tight, controlled and safe. You will never worry about them again.
For your loose folding knives and small objects (wrenches, clips, screws, handles) Use bags of some sort to keep them from banging around and scratching. Either ziplock or some bag that is the perfect size.
http://www.valley-marine.com/watertight-container-large_8_229_31805.html
Bags:
http://i01.i.aliimg.com/photo/v0/466954129/Apple_baggies.jpg Cheap, disposable and will keep your knives from scratching each other.
:thumbup: :thumbup:
For bigger storage needs:
http://www.ebay.com/itm/HARDIGG-MIL...713?pt=LH_DefaultDomain_0&hash=item2ecbbf3631. You will need to find another listing, this one is old and just for reference.
