i think he was talking about a Organized place to put them!! (He-He)Well, when you ask..........................
Scattered around the shop, I search for them for hours sometimes . If I find them , I'm happy![]()
I have a KMG tool arm holder that bolts to the base plate. It holds the arms at an upward angle.
At 70 and ill I struggle to lift the arm+attachment out of the holder nowadays with the grinder a little above waist height. I think having the arms parallel to the ground would have been a bit better. Some day, if I ever weld again, I may secure it to a weighted base on the floor.
Thanks, a lot of good ideas. I am running out of space in the shop and the make do tables need to go out to make for a more reasonable use of space.Make a "tree" for the arms. Use square tubing that is a bit bigger than the arms.
Take a section of 2.5" flat bar about 24" long. Cut the square tubing at around 30° to make a bunch of 6" pieces. Weld them along the bar every 4-6". Bolt the bar to the wall or the leg of a bench. Drop your arms in the "branches". To store wheels and other tooling, do the same, but use pieces of 3/8" round stock for the branches. Weld them at about 10° . Just stick the wheels on the pegs. using 6" pegs, you can stack several wheels on each one.
Small stuff and jigs are best put in a clear storage bin with a big label saying "Grinder Tools". Store that on the floor under the bench. The small tools and things ( box wrenches, Allen wrenches, screwdrivers, etc.) should be in a small clear plastic storage bin and kept on the bench or a shelf over it.
For a really cheap wheel storage, screw 8-9" lag screws into the 2X4 shop wall studs and cut the heads off, leaving around 6" to drop wheels and jigs on..
I was thinking I could store the arms and tools under the bench to keep out of the grinding dust and maybe do some kind of hanging arm holders in which they would slide into paralel to the ground. I have basically 4 arms (flat platen, table, wheel and small wheel).
Welder is on the the top of the shopping list. I am thinking a small MIG/MAG 180-200 A inverter unit that can do flux wire and stick welding will get me started?
I need to finish the cargo bike to get it out of the shop and start rearranging everything. No knifemaking in the near future. Patience, young padawan.
Is that Sherline mill in corner ??? What are you using it for ? I've been thinking for a few years about buying them /lathe + mill/ .They have so many accessories...........![]()
Thats a piece of oak baseboard drilled for the tool arms, held up with some simpson stongtie brackets...total cost = 0 dollars
That is a Sherline and 95 percent used for slots in guards, almost every knife I make gets a guard and I hate filing slots. It works well for my purposes but it is definitely size/ rigidity limited.Is that Sherline mill in corner ??? What are you using it for ? I've been thinking for a few years about buying them /lathe + mill/ .They have so many accessories...........
I think room constraints force you to be. When I work and change between arms I will just put them anywhere I have place. Thankfully they are big enough in order not to lose them. Other stuff gets misplaced often enough.Dang some of ya guys are organized. I'm more like Natlek. I gotta em in a box on a shelf under the bench.
Same.I'll be honest ... most of the time I set the arm on the floor leaning against the bench when I switch from flat platen to rotary platen to contact wheel. The two I am not using are right there by my legs and ready for a fast change. The other wheels and arms are stored on pegs and tubes.
That's neat! One cart to rule them allRelatively small space here, so my grinder setup is portable so I can wheel it around the garage as necessary. I'm planning on adding a sliding shelf for the water bucket so I can simply pull it out when in use.
Edit: I keep my small wheel attachment on metal pegboard nearby, and the various small wheel attachments and jigs/soft platen attachment etc in metal drawers also nearby.
I'm a mega Tolkien fan, so I particularly appreciate this comment, thanks haha!That's neat! One cart to rule them all![]()
