This is the safest, and most practical storage solution for your gear short of buying a heavy safe that is bolted to the ground. This will cost you about $250 dollars. Well worth the money to protect your gear and keep it available, moveable, in perfect condition, and ready to use.
This is what recommend to use. Waterproof, durable, and air tight.*** For all storage of outdoor gear and valuables. The foam can be cut with any serrated kitchen knife to your needs, as well as completely removed. Areas can be cut in the foam in the lid and bottom foam to insert flashlights (AAA Maglights), tools (Wrenches), and small knives. VERY durable case, completely waterproof, THICK heavy duty plastic. Pressure relief valve for pressure equalization, so it will be fine if it is shipped in a plane. This case can literally be dropped over twenty feet, have tree limbs fall onto it, and survive a hurricane and be left outside for a month. When you open it, your gear will be in the same condition that it was in when you put it into the case. The only problem is there is no standard way to lock the case up.... So a solution to this is two 1/8 inch "U bolts" with four 1/8 inch metal and rubber washers to attach on either side with a nut and a wing nut. End nut, washer, rubber washer, Hardigg, rubber washer, washer, nut. Mark and drill the holes, and make it permanent by liberally applying an Epoxy or Gorilla Glue.
**Place the U bolts in the best position to fit a bike lock or a master lock. Place where ever you would like on the box for the best convenience and security.
DESSICANT*** Use at least 60-100grams for your hardigg, this will repel water and keep your box moisture free. Dessicant absorbs and displaces humidity and moisture in a confined area. It will pull the water from the air into itself so your gear stays dry and rust free. You can recharge these in an oven and reuse them. Definitely worth buying. Paired with oil, your gear should never rust.
You metal goods are secure, easily moveable, moisture and air tight, controlled and safe. You will never worry about them again.
Now for your small gear that can't be wrapped in a cloth or bandanna or rubber banded or secured in the foam....
You don't want your folding knives banging around against each other. This will scratch them up and destroy finishes or worse...
For your loose folding knives and small objects (wrenches, clips, screws, handles) Use bags of some sort to keep them from banging around and scratching. (A head shop is really the best place to find bags of all different sizes. You can also find bags in bulk at places like Hobby Lobby, Michaels, and sowing specialty stores as well. Either ziplock or some bag that is the perfect size. Buy a lot of plastic bags. You will be grateful to yourself later for doing this.
For bigger storage needs go with a larger hardigg. Plano makes storage boxes that are great for gear in larger hardiggs (Tackle boxes:stackable)
You can store your BoB's and survival/hunting gear in these along with valuables and anything else you may want to take with you...
Feel free to post any storage ideas here. Any advise would be helpful and appreciated.
