Story: I love sticks
I have had a loving relationship with sticks for a long time. I guess one reason is my martial arts training; I used to train escrima many years ago. This art uses sticks as a both a training weapon, but it is also a weapon in its own right. The Filipino stick is usually short, around 60-70 cm long but it can be longer, up to a man’s length pole.
Still my favorite is a walking stick length, around 90 cm, sometimes a bit longer. There is just something positive and reliable in a good, stout stick. If it is well made, of good wood and if you take even some care of it, it will serve you a lifetime. It can do many jobs, from self-defense to supporting you in rough terrain. It is the mankind’s oldest tool, still useful today.
From self-defense point of view the walking stick is unsurpassed, but still it has some limitations. The first and most important thing is that you must be of certain age to be able to carry a stick or police might take a dim view of both you and your stick. If you are of suitable age, no one will really notice that you have a walking stick. Of course, the stick should match your dress to make a proper impression. There are many kinds of sticks available, from gentleman’s silver-knobbed sticks to the most usual, the crooked handle walking stick usually seen in the hands of older people. You could get away by explaining that you have bad knee if you are not of proper age.
I will not get into details about how you could use your stick to defend yourself or others; I just make a passing remark to a fictional character, Sherlock Holmes. There is no incidence of Holmes using an actual sword on any of his cases, but one of his other noted athletic pursuits does in fact derive from the usage of the blade. Singlestick, also sometimes referred to as cudgel-play, was a method of fencing that simulated the use of the broadsword and sabre, and was to these weapons somewhat as the foil is to the rapier or court (small) sword. Practiced as it was with a round wooden rod about forty inches in length, skills acquired in this game could be immediately applied to defending oneself with the gentleman’s walking stick. In “The Adventure of the Illustrious Client”, Holmes goes up against multiple assailants and despite his singlestick expertise, comes off second best:
“I’m a bit of a single-stick expert, as you know. I took most of them on my guard. It was the second man that was too much for me.”
Teddy Roosevelt himself said: “Speak softly, and carry a big stick”. Roosevelt, by the way, also practised singlestick. With that I can leave this point.
When you want to make yourself a stick things get interesting if you are a knife collector and like to use knives for whittling. That brings us to my favorite type of walking stick, the Irish Shillelagh with the knob and the shaft made of one piece of wood.
I have made some sticks of the wood I could find from the forest. If you plan to cut down a suitable tree, make sure that you have landowner’s permission to do so if you are not a landowner. The trees that are suitable for that use are usually those that are not used in forest industry so they have little value.
To start a process of making a stick you need very few things. You need a small axe, most definitely a good knife for whittling and some sandpaper. If you really want to indulge yourself you can get a rasp. For finishing and protecting the stick you need wood oil, I use teak oil.
The most important thing is finding a suitable tree. I choose two trees that are native to my homeland, the Birch and the Mountain Ash. Of these two birches are lighter but not as though as mountain ash, so I prefer the latter. When you search the proper wood look at these things: the straightness, the diameter of the wood and don’t forget to look at the roots, because those are used to make the knob. The best trees are those that started their life growing a little crooked, but as they grew they straightened themselves, leaving a curve and a root knob in the ground.
Now you might have to dig out the root knob so a small spade might be useful but not absolutely necessary. You can get your hands dirty and remove some earth just by hand. Use the axe to cut through the roots and take care not to harm the knob. Then cut the tree to slightly longer length that you want to use.
Now you need your knife. You peel the bark off the tree and start whittling the stick to rough shape. After that you will need a lot of patience because the wood has to dry for some time. Don’t take shortcuts in drying, because forcing the process might split the wood. Some splitting is to be expected. The trick is to leave the stick longer than you plan to use and leave some bark in place in the ends of the stick. You could put some glue or paint on the ends; those are easy to take off later. Put the stick in a dry place where it is not in direct sunlight and wait. It will take up to a year for the wood to dry properly so don’t hurry!
After this you can again take your knife and start shaping your stick. There is something very soothing in working the wood with hands and a knife. It is like meditation, there are just you, your sharp knife and the wood. It is an exhilarating moment when the stick you are whittling is finally starting to get the shape you want. Remember that it is easy to take off wood but impossible to put it back, so go slow. What type of knife you use is irrelevant, as long as it works. I have used a small Finnish puukko, you might use your trusty pocket knife as well. Use what you are most familiar with, that is part of the charm of this process.
The knob is most important for your comfort so take your time to try it in your hand once in a while. When you have reached the shape you want you can start to use the sandpaper. You put the final shape and finish on the wood by sanding it, fine tuning the knob to your taste.
Now you are ready to cut the stick to preferred length. Now is also your chance to ruin the whole thing! My preference is to put on the shoes I will use with this stick, so I have to know if I am using the stick in forest or in the city. I take a relaxed standing position with my legs straight but not locked, arms hanging down, put the knob on the ground beside my leg and make a small mark where the shaft of the stick reaches my wrist. I cut the stick carefully with a fine-toothed saw (yes, you need that too) to this length. After that you just oil the stick and leave to dry for a night.
It is a good idea to put a rubber ferrule on the end to protect the wood. After this your stick is ready. You can make leather or cord loop and attach it to your stick to hang it from your wrist.
Your stick can be part of your personality, your history. My father found a very old stick made by a German soldier in Lapland. The stick had carvings on it. There was sun shining on a farmhouse, Edelweiss and a text “Heimat”, homeland, on the shaft. Can you imagine the homesickness the poor young man must have felt when he was carving this stick? I hope he survived to see his home again.
If you are really into this you can fine-tune the balance. You must take different grips of the stick, swing it like a sword, take small walks with it and feel how the stick responds. Then you can put more taper to the stick if you want. At this point you are like a sword smith, who must have intimate knowledge of his craft to make a truly fine sword.
My sticks I use mostly when walking through the forest to give me support. The day may come when I must use them also in the city for that. May the day never come when I have to use them to defend me or my loved ones, but I am sure they are ready also for that.
Thanks HFinn. That was real good. I also like a good stick and have saved me from falling several times while walking in the knobs(steep hills) where I live. I like a good hickory or dogwood stick. Both woods seems real tough. I cut mine off with a SAK with a saw blade.
Yeah, I like sticks as well. I've made some like these, cut from local woods. The one on the right is maple, second from left a Blackthorn, middle one was a young hickory sappling I cut and whittled the root ball handle with a peanut, the fourth from left is a hornbeam also called iron wood, and I whittled the dogshead shape of the root hadle with the pen blade of a chestnut peanut. I wanted it to fit my hand perfectly. The one on the far right I didn't make, but it's an old Blackthorn I brought back from England. It's very heavy and thicker than normal, so it's my 'downtown' stick. I found the pen blade of the 'nut to be perfect for the whittling of the handle shape, taking a very little bit at time until it felt just right in my hand. Pocket knives were meant for making sticks. :thumbup:
Carl.
edit to add; So many times a pocket knife has been used to make a stick for someone who doesn't have one, but needs one. Karen and I have a few friends who are real city slickers. We'd take them on a hike, and soon it was obvious a stick was needed on a very rocky uphill trail. I'd use whatever pocket knife I had on me to notch and break a stick from a deadfall that wasn't rotted yet. They'd always be amazed at how a small pocket knife cut the stick off. Then I'd hold it up next to them to figure how long it needed to be trimmed off. Rib high or shoulder high. Then I'd show them how to use a small knife to notch and break. Of course I'd use my old man's line. "It doesn't have to be big, just sharp."
Thanks for writing this up.
I like sticks too. Partly it's traceable to the escrima I practiced in college. Mostly I think that little boys like sticks and I never grew out of it.
I don't have a walking stick, but I really want one of these. Part stick, part sharp, 100% cool. It's called a fokos, or more generically, a shepherd's axe.
- Christian
Cool post!
I'm also a fan of the Irish-style shillelagh, and have made myself a couple. ...although my methods are somewhat less refined. Instead of uprooting a sapling, I have successfully used a branch of appropriate thickness, taking the knob from the joint where the branch shoots off of the larger limb.
The tools I usually use are simple: folding saw of some type, and whatever pocket knife I have. Also, I leave the bark in place along the length of the stick, and hang it to dry for a year or so before any shaping/finishing.
Have to snap some pics some time...
Great post, HFinn :thumbup:
I've bookmarked this one for future reference...
Great post! One thing to add for interest is the time of year to harvest your stick. If you wait till winter, the wood is much drier as the fluid is stored in the roots. In my experience these sticks have much less chance of cracking. In spring the wood is very moist and can crack easily in my experience :)
Thanks for the read as always Finn
Good day knife nuts!
I like this thread. I'll keep liking it as long as the discussion includes cutting, carving, tweaking, or embellishing a walking stick with a traditional knife. You get my drift?:)
We understand that a walking stick can also ward off the neighbors dog etc, if need be. Let's not dwell on the self defense aspects, as that's for a different forum.
Thanks!
Sticks and knives, love and marriage, horse and carriage - great topic!! Great thread, HFINN!
Wonderful collection, Carl!
- Christian
Actually I thought about you when writing this, since I had the impression that you had some FMA-experience. As a historical fencer sticks (singlestick) are part of our training. When we are doing our footwork exercise our teacher can shout "stick is in the play" and comes with a 90 cm stick, striking at people. Our job is to adjust our footwork so that he won't hit us. If he does it is 10 pushups every time. And that Fokos I know, when I was a child I used to watch a series about a Hungarian folk hero who used the Fokos to fight bad guys.
When I was in high school, my friend Dave had an uncle living with them. This old uncle was retired, and needed a cane. Being the very stubborn old man he was, he refused to use a store bought "old Fogy" cane, but one he had made. He'd cut some wood, and for months, sat on the front porch using the pen blade of an old barlow to carve his cane. He's started at the base, and made it look like a vine was curling around the stick, all up the length of it to the top where he had flowers carved, in relief. It was one heck of a piece of art!
All done with just the pen blade of an old barlow. So many years ago, I wish I could remember what brand of barlow it was.
That is true, but the area where I can harvest sticks is where we go during summer. After that I put the sticks in my cellar, where it is cool and dry for a year. I havent experienced much cracking that way.
Thanks everybody for your kind comments again! And sorry that I allways seem to drift outside the forum's topic. :o
Here is another stick I made from American hornbeam/ironwood. I found a sapling with a root running off almost 90 degrees, so I actually harvested it with the saw blade of a SAK. After letting it sit drown the basement for alomost a year, I used an Opinel number 6 to shape the handle. If you look closely at the handle, there is a slight thumb groove in the side of the handle. I shaped the top and bottom of the root handle to my hand, just taking very very small flakes with the Opinel, then using the blade at 90 degrees as a scraper. I found the round handle of the Opinel was perfect for comfort inlong term use. Final sanding was with 500 paper and 0000 steel wool. Finish was Tandy leather die medium brown, and satin finish Helmsman spar urethane.
This may be my favorite stick for dress up occasions.
That's a nice looking stick, Carl. I've carved a few staffs in my time, always using a traditional fixed blade and slip joint. ;) Many years ago my oldest son used one in a Christmas play at school. He was one of the shepherds.
I'm getting to the age where I get a twinge in the knee or hip, if I'm out hiking or walking, so a stout stick or staff sure comes in handy.
These are mine. One of those I bought but did some customizing, I carved the shaft a bit oval and waxed the whole thing. I took quite a lot of wood off it. One those needs a new ferrule and I will also reinforce the tip with a piece of copper tube as I have done with some others.
Thanks for thinking about me. You are right, I have some FMA experience, but nothing too serious. More than anything it was a fun way to touch base with my heritage (I'm ethnically Filipino). I really should start up again. Now that I'm getting older it's getting harder to stay in fighting trim. I'd much rather practice escrima than join a gym.
- Christian
this one was carved with mostly a Sodbuster and my Bower brand Barlow. It was a small oak sapling...it comes in pretty handy when the gout flares up.
Let me warn ya now bud, it does not get any better.:eek:
A stick takes a heck of a lot of strain off ankle and knee joints if used right. It's alsi soooo useful on unstable ground.
Man walking upright is a basically unstable creature. Karen's youngest sister when on a hile with us several years ago, when she was in her 40's. It was a rocky very uphill trail in the Catoctain state park, to place called Wolf Rock. A heck of a clim up on poor rough trail with a lot of loose rock. Romellie was sure she didn't need a hiking stick. About 20 minutes into the hike, she had changed her mind. I found a blow down with a very vertical limb sticking up that was well dried, and not rotted. As I had described elsewhere, I notched and cut off and made a stick in a few minutes. Rom loved it. After the hike down, that was actually harder than going up, Romellie admitted she'd never thought a stick could be so important on a hike. Of course, she's a south Texas girl like Karen, who grew up in a pretty flat area.
A pocket knife, a downed tree, and few minutes time, change a man from an unstable Biped to a three legged critter that doesn't fall down as much when the going gets rough.:D
Carl.
